xlsx file log to nagios log server using NXLogCE
Techmnagioslsuser
Post by Techmnagioslsuser »
Hello Team,
One of our log source has a file extension xlsx. We send teh logs from the log source using NXLog CE configuration.
.txt , .log, .csv all logs are being captured. How to capture .xlsx log file. Please suggest
gsmith
Re: xlsx file log to nagios log server using NXLogCE
Post by gsmith »
Hi
NXLog CE is not one of our products. I did look at it, and you cannot configure
it to read xlsx. You would need to create a script incorporating an xlsx to csv
converter, then NXLog SE would be able to handle it.
