How to monitor tftp server which is having ipv6 address
vasanth
Post by vasanth »
How to enable monitoring for tftp server which is having iPV6 address. Existed check_tftp.pl not working with ipv6 addresses . Please provide solution for this
vasanth
Re: How to monitor tftp server which is having ipv6 address
Post by vasanth »
Please provide check_tftp plugin which support ipv6 addresses
gsmith
Post by gsmith »
It does support IPV6 addresses:
[root@gs-cent8-23-82 libexec]# ./check_tftp.sh --connect 192.168.23.86
OK - answer from server
[root@gs-cent8-23-82 libexec]# ./check_tftp.sh --connect fe80::6e61:ad35:228a:9e1d
[root@gs-cent8-23-82 libexec]# ./check_tftp.sh --get fe80::6e61:ad35:228a:9e1d file2.txt 13
OK - Received file successfully
My guess is that you need to open up your firewall on either the tftp server or your xi server or both.
Also make sure SELinux is disabled.
Let me know how it works out.
vasanth
Post by vasanth »
Can you share the check_sftp.sh
benjaminsmith
Post by benjaminsmith »
The plugin tested above is available on the Nagios Exchange:
https://exchange.nagios.org/directory/P ... sh/details
Other plugins in this category are available as well.
https://exchange.nagios.org/directory/P ... ocols/TFTP
If you need assistance on how to install and configure a plugin, please review the guide below.
Third-Party Plugins in Nagios XI
https://support.nagios.com/kb/article/t ... i-883.html
Let us know if you need any help testing.
--Benjamin
vasanth
Post by vasanth »
Hi Smith,
Thanks for the support , I have modified existed perl script to check IPv6 as well.
benjaminsmith
Great! That's good news.
We'll go ahead and mark this as resolved, but feel free to open another post if you have any new questions.
Benajmin
