Hello Team,
Can we use Filebeat agent for forwarding log from linux log source to Nagios log server. Please suggest.
Filebeat agent for linux log source
Techmnagioslsuser
Re: Filebeat agent for linux log source
Yes, this is possible. https://www.elastic.co/guide/en/beats/f ... arted.html has the steps for installing the agent and forwarding the logs to various outputs. You'll want to configure an output to forward the logs to the NLS machine where you'll have set up a beats input(https://www.elastic.co/guide/en/logstas ... beats.html) under Configure > Global Config(https://assets.nagios.com/downloads/nag ... Inputs.pdf) which can be as simple as:
beats {
port => 5044
}As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
