AIX monitoring with SNMP doesn't work
ABBsupervision
We're trying to configure SNMPv3 on AIX to check its status through XI but we doesn't succeed.
We followed your instructions based on https://assets.nagios.com/downloads/nag ... g-SNMP.pdf
The logging is not written on /usr/tmp/snmpdv3.log as specified on conf file, instead we got error message on /usr/tmp/snmpd.log as follow:
06/11/21 15:45:18 EXCEPTIONS: decode_SNMP_Message: pr_seq:missing mandatory parameter: module SNMP OBJECT/class=UNIV/id=1 got CONT/5 (::ffff:<IP_Nagios_Server>)
We added following lines on conf files:
VACM_VIEW defaultView system - included -
VACM_VIEW defaultView interfaces - included -
VACM_VIEW defaultView tcp - included -
VACM_VIEW defaultView icmp - included -
VACM_VIEW defaultView udp - included -
VACM_VIEW defaultView snmp - included -
VACM_VIEW defaultView 1.3.6.1.2.1.25 - included -
Since it didn't change anything we made following change (change excluded by included):
VACM_VIEW defaultView snmpModules - included -
But still not working.
Any idea on how to resolve our issue please.
Thanks & regards
Thanks & regards
Re: AIX monitoring with SNMP doesn't work
Can you please try this - I want to see where we're at with communication between the
xi server and the AIX box:
On the xi server:
cd /usr/local/nagios/libexec
./check_snmp_storage.pl -H <ip of AIX machine> -C <v3 communityname> -m "^/$" -w 2 -c 4
This check should return disk usage information from the remote AIX server, something like:
/: 11%used(1550MB/13892MB) (>4%) : CRITICAL
If it doesn't please provide the following files from the AIX machine:
/var/tmp/aixmibd.log
/var/tmp/hostmibd.log
/var/tmp/snmpdv3.log
/var/tmp/snmpmibd.log
/etc/snmpd.conf
Here is a good resource for AIX: https://nagios.fm4dd.com/howto/aix-snmp-setup.shtm
On the xi server:
/etc/snmpd.conf
ABBsupervision
Hello gsmith,
When a run this command i got this resultat :
Please find attached the following files from the AIX machine.
Best Regards,
SOUHAIB
[root@DCPNAGIOSXIN1 libexec]# ./check_snmp_storage.pl -H <ip of AIX machine> -C <v3 communityname> -m "^/$" -w 2 -c 4
ERROR: Description/Type table : No response from remote host "ip of AIX machine".
Best Regards,
SOUHAIB
Hi
On the nagios server run:
Note: You may have to install nmap
If you get:
Then you need to allow port 161 UDP on the AIX machine's firewall
Once you get:
then try these four commands:
nmap -sU -p 161 <ip of AIX machine>If you get:
Host is up (0.00068s latency).
PORT STATE SERVICE
161/udp closed snmpOnce you get:
PORT STATE SERVICE
161/udp open|filtered snmpCode: Select all
snmpwalk -v1 -c ABB <ip of AIX>
snmpwalk -v2c -c ABB <ip of AIX>
snmpwalk -v2c -c ABB <ip of AIX>-
ABBsupervision
I inform you that the port is open as you can see via the following command :
And following your request here is the result of the four commands :
Best Regards,
SOUHAIB
[root@DCPNAGIOSXIN1 ~]# nmap -sU -p 161 <ip of AIX machine>
Starting Nmap 7.70 ( https://nmap.org ) at 2021-06-15 09:30 +01
Nmap scan report for <Name AIX machine> (x.x.x.x)
Host is up (0.00065s latency).
PORT STATE SERVICE
Nmap done: 1 IP address (1 host up) scanned in 6.01 seconds
[root@DCPNAGIOSXIN1 ~]# snmpwalk -v1 -c ABB <ip of AIX machine>
Timeout: No Response from x.x.x.x
[root@DCPNAGIOSXIN1 ~]# snmpwalk -v2c -c ABB <ip of AIX machine>1
SOUHAIB
ABBsupervision
Any news about our request ?
It's urgent please.
Thanks & regards
It's urgent please.
Thanks & regards
Try this :
snmpwalk -v1 -c public <ip of AIX>
snmpwalk -v2c -c public <ip of AIX>
ABBsupervision
Hi gsmith,
We tried both snmpwalk command and we got the same message :
Timeout: No Response from <IP_AIX>
We changed the community from public to <our_community> for both commands.
In SNMP version 2c we got the same Timeout / No Response error message
In SNMP version 1 it works
The SNMP v1 is already working as the AIX was monitoring by an old version of Nagios Core.
Since we deployed XI in replacement of the old version, we lost the AIX monitoring ability, since XI is using only SNMP version 2c or 3.
Any other suggestions ?
Thanks & regards
Thanks & regards
Hi
What does the link show?
edit /etc/snmpdv3.conf
change:
to:
Then try the snmpwak from the nagiosxi server.
cd /usr/sbin
ls -l snmp*
change:
COMMUNITY ABB ABB noAuthNoPriv 0.0.0.0 0.0.0.0 -Code: Select all
COMMUNITY ABB ABB noAuthNoPriv <ip of nagiosxi> 255.255.255.255 -Code: Select all
stopsrc -s aixmibd
stopsrc -s hostmibd
stopsrc -s snmpmibd
stopsrc -s snmpd
startsrc -s aixmibd -a "-c ABB"
startsrc -s hostmibd -a "-c ABB"
startsrc -s snmpmibd -a "-c ABB"
startsrc -s snmpdThanks
ABBsupervision
Please find the order result below :
We have modified the file in the AIX server, as well as the execution of the mentioned commands.
But when we launch the snmpwalk nothing happens.
Best Regards,
SOUHAIB
[root@DCPNAGIOSXIN1 ~]# cd /usr/sbin
[root@DCPNAGIOSXIN1 sbin]# ls -l snmp*
-rwxr-xr-x. 1 root root 33352 11 août 2020 snmpd
-rwxr-xr-x. 1 root root 33504 11 août 2020 snmptrapd
-rwxr-xr-x. 1 root root 177455 7 nov. 2013 snmptt
-rwxr-xr-x. 1 root root 6488 7 nov. 2013 snmptthandler
[root@DCPNAGIOSXIN1 ~]# snmpwalk -v 2c -c ABB x.x.x.x
SOUHAIB
