Ghost hosts won't go away
ockmeyer
Post by ockmeyer »
I deleted three hosts and all their associated services, but they still show up in the NagiosXI minemap.
I've tried killall nagios, service nagios start
I've deleted the config files from /usr/local/nagios/etc/hosts and /services
The write config files tool in CCM return no errors and the check config files comes back fine. Restarting nagios doesn't help.
I've scrubbed the forum but haven't found anything new to try.
NagiosXI 2011R3.1, Nagios Core 3.4.1, NagiosQL 3.0.3.
Suggestions?
Re: Ghost hosts won't go away
This problem may be related to the following wiki
http://support.nagios.com/wiki/index.ph ... 3.x_Issues
Also, lets force a restart of ndo2db
service ndo2db stop
killall -9 ndo2db
service ndo2db start
ockmeyer
Post by ockmeyer »
My settings in sysctl.conf match the article. When I try to stop ndo2db I get the message:
Stopping ndo2db: head: cannot open `/usr/local/nagios/var/ndo2db.lock' for reading: No such file or directory
done.
But the file is there
agriffin
Post by agriffin »
This sounds like a permissions issue. What output do you get running the following command?
ls -ld /usr{,/local{,/nagios{,/var{,/ndo2db.lock}}}}
ockmeyer
Post by ockmeyer »
-rw-r--r-- 1 nagios nagios 5 Jun 25 15:04 /usr/local/nagios/var/ndo2db.lock
agriffin
Post by agriffin »
That doesn't seem to be from the same command I posted; those braces and commas were important too. I need to see the directory permissions on everything above it to know whether ndo2db can use the file. Would you mind running it again?
ockmeyer
Post by ockmeyer »
Sorry...Linux newbie
drwxr-xr-x. 13 root root 4096 Oct 31 2011 /usr
drwxr-xr-x. 17 root root 4096 Jun 25 10:50 /usr/local
drwxr-xr-x 8 root root 4096 Aug 29 2011 /usr/local/nagios
drwxrwxr-x 6 nagios nagios 4096 Jun 25 15:09 /usr/local/nagios/var
Does /usr/local/nagios need different permissions?
ockmeyer wrote:My settings in sysctl.conf match the article.
The article says once you confirm they are correct you need to run the following to apply the new settings. If the system still appears to be working improperly, reboot the machine.
sysctl -p
agriffin
Post by agriffin »
Your permissions look fine, give scott's advice a try though.
ockmeyer
Post by ockmeyer »
I ran sysctl -p and rebooted after checking the settings. No luck.
