This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
theo481
Posts: 9 Joined: Tue Sep 01, 2020 10:26 am
Post
by theo481 » Tue Jun 15, 2021 12:00 pm
Made some changes in CCM, getting an error:
Error: Contact 'XXXXXX' has no service notification commands defined!
Error: Contact 'XXXXXX' has no host notification commands defined!
Went into backend, opened up the contacts.cfg and that contact doesn't exist, checked contactgroups.cfg and not in there either.
ran ./reconfigure_nagios.sh and here is the output
--- reset_config_perms.sh ------------
> Setting script permissions
> Setting CCM script permissions
> Setting special script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
/bin/chmod: cannot access ‘/usr/local/nagios/share/perfdata/jboss7/Swap_Usage.xml’: Input/output error
/bin/chown: changing ownership of ‘/usr/local/nagios/share/perfdata/jboss7/Swap_Usage.xml’: Input/output error
> Setting libexec directory permissions
> Setting Nagios XI config permissions
> Setting NOM checkpoint user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
Could not open input file: /usr/local/nagiosxi/scripts/ccm_import.php
Importing into the CCM failed!
Would appreciate any help
vtrac
Posts: 903 Joined: Tue Oct 27, 2020 1:35 pm
Post
by vtrac » Tue Jun 15, 2021 4:40 pm
How are you doing?
Could you please run the below command and upload outputs?
ls -la /usr/local/nagios/share/perfdata/
ls -la /usr/local/nagios/share/perfdata/jboss7/
rm -f /usr/local/nagios/etc/import/*
Please open Nagios XI GUI > Configure > Core Config Manager > Config File Management
Now, please click "Delete Files"
Please click "Write Configs"
Please click "Verify Files"
Once verified with no error, please click "Apply Configuration" on the upper left panel.
Best Regards,
Vinh
theo481
Post
by theo481 » Wed Jun 16, 2021 10:26 am
I'm going to skip the output of the first one, as it has a lot of sensitive data, here is the second one, and the rm commands fixed the saving of the config. A handfull or warnings, but no errors.
[thbhagya@nagios-prod ~]$ ls -la /usr/local/nagios/share/perfdata/jboss7/
ls: cannot access /usr/local/nagios/share/perfdata/jboss7/Swap_Usage.xml: Input/output error
total 32088
drwxrwxr-x 2 nagios nagios 258048 Jun 16 09:11 .
drwxrwxr-x. 859 nagios nagios 36864 Jun 7 15:04 ..
-rw-rw-r-- 1 nagios nagios 384952 Jun 16 09:11 CPU_Usage.rrd
-rw-rw-r-- 1 nagios nagios 2196 Jun 16 09:11 CPU_Usage.xml
-rw-rw-r-- 1 nagios nagios 1151496 Jun 16 09:08 Disk_Usage_on__r01.rrd
-rw-rw-r-- 1 nagios nagios 3603 Jun 16 09:08 Disk_Usage_on__r01.xml
-rw-rw-r-- 1 nagios nagios 1151496 Jun 16 09:08 Disk_Usage_on__.rrd
-rw-rw-r-- 1 nagios nagios 3578 Jun 16 09:08 Disk_Usage_on__.xml
-rw-rw-r-- 1 nagios nagios 384952 Jun 16 09:11 eth0_Bandwidth_-_Inbound.rrd
-rw-rw-r-- 1 nagios nagios 2317 Jun 16 09:11 eth0_Bandwidth_-_Inbound.xml
-rw-rw-r-- 1 nagios nagios 384952 Jun 16 09:08 eth0_Bandwidth_-_Outbound.rrd
-rw-rw-r-- 1 nagios nagios 2323 Jun 16 09:08 eth0_Bandwidth_-_Outbound.xml
-rw-rw-r-- 1 nagios nagios 1534768 Jun 16 09:08 _HOST_.rrd
-rw-rw-r-- 1 nagios nagios 3937 Jun 16 09:08 _HOST_.xml
-rw-rw-r-- 1 nagios nagios 1534768 Jun 16 09:08 Memory_Usage.rrd
-rw-rw-r-- 1 nagios nagios 4245 Jun 16 09:08 Memory_Usage.xml
-rw-rw-r-- 1 nagios nagios 1151496 Jun 16 09:10 Swap_Usage.rrd
-?????????? ? ? ? ? ? Swap_Usage.xml
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 20:21 Swap_Usage.xml.10022
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 14:35 Swap_Usage.xml.10024
-rw-rw-r-- 1 nagios nagios 3522 May 31 08:02 Swap_Usage.xml.10033
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 11:12 Swap_Usage.xml.49789
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 00:54 Swap_Usage.xml.49795
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 07:18 Swap_Usage.xml.49802
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 04:09 Swap_Usage.xml.49806
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 15:29 Swap_Usage.xml.49823
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 15:34 Swap_Usage.xml.49829
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 08:41 Swap_Usage.xml.49840
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 07:09 Swap_Usage.xml.49858
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 14:40 Swap_Usage.xml.49869
-rw-rw-r-- 1 nagios nagios 3522 May 26 05:27 Swap_Usage.xml.49870
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 20:27 Swap_Usage.xml.49878
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 01:16 Swap_Usage.xml.49894
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 17:06 Swap_Usage.xml.49901
-rw-rw-r-- 1 nagios nagios 3522 May 30 01:27 Swap_Usage.xml.49911
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 09:00 Swap_Usage.xml.49937
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 16:58 Swap_Usage.xml.49958
-rw-rw-r-- 1 nagios nagios 3522 May 27 16:59 Swap_Usage.xml.49969
-rw-rw-r-- 1 nagios nagios 3522 May 26 07:26 Swap_Usage.xml.49995
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 07:10 Swap_Usage.xml.49998
-rw-rw-r-- 1 nagios nagios 3522 May 26 21:11 Swap_Usage.xml.50004
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 07:01 Swap_Usage.xml.50017
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 20:50 Swap_Usage.xml.50020
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 23:49 Swap_Usage.xml.50022
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 08:09 Swap_Usage.xml.50027
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 23:30 Swap_Usage.xml.50041
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 00:44 Swap_Usage.xml.50045
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 23:30 Swap_Usage.xml.5005
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 14:12 Swap_Usage.xml.50066
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 18:57 Swap_Usage.xml.50068
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 04:15 Swap_Usage.xml.50070
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 19:36 Swap_Usage.xml.50084
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 21:00 Swap_Usage.xml.50087
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 16:33 Swap_Usage.xml.50091
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 09:50 Swap_Usage.xml.50096
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 09:41 Swap_Usage.xml.50110
-rw-rw-r-- 1 nagios nagios 3522 May 31 23:12 Swap_Usage.xml.50113
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 07:42 Swap_Usage.xml.50119
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 01:55 Swap_Usage.xml.50130
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 17:44 Swap_Usage.xml.50131
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 02:07 Swap_Usage.xml.50150
-rw-rw-r-- 1 nagios nagios 3522 May 25 03:46 Swap_Usage.xml.50161
-rw-rw-r-- 1 nagios nagios 3522 May 27 20:58 Swap_Usage.xml.50190
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 20:56 Swap_Usage.xml.50211
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 13:50 Swap_Usage.xml.50213
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 03:53 Swap_Usage.xml.50215
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 03:10 Swap_Usage.xml.50223
-rw-rw-r-- 1 nagios nagios 3522 May 25 07:45 Swap_Usage.xml.50232
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 03:51 Swap_Usage.xml.5024
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 05:10 Swap_Usage.xml.50240
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 06:51 Swap_Usage.xml.50262
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 08:47 Swap_Usage.xml.50263
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 13:11 Swap_Usage.xml.50272
-rw-rw-r-- 1 nagios nagios 3522 May 26 11:24 Swap_Usage.xml.50278
-rw-rw-r-- 1 nagios nagios 3522 May 25 13:37 Swap_Usage.xml.50280
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 13:12 Swap_Usage.xml.50283
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 21:23 Swap_Usage.xml.50310
-rw-rw-r-- 1 nagios nagios 3522 May 26 09:25 Swap_Usage.xml.50314
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 07:21 Swap_Usage.xml.5033
-rw-rw-r-- 1 nagios nagios 3522 May 31 09:16 Swap_Usage.xml.50333
-rw-rw-r-- 1 nagios nagios 3522 May 30 19:21 Swap_Usage.xml.50336
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 11:56 Swap_Usage.xml.50341
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 19:05 Swap_Usage.xml.50346
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 21:38 Swap_Usage.xml.50347
-rw-rw-r-- 1 nagios nagios 3522 May 28 04:55 Swap_Usage.xml.50365
-rw-rw-r-- 1 nagios nagios 3522 May 30 21:20 Swap_Usage.xml.50379
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 05:56 Swap_Usage.xml.50391
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 00:21 Swap_Usage.xml.50415
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 06:46 Swap_Usage.xml.50416
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 17:33 Swap_Usage.xml.50424
-rw-rw-r-- 1 nagios nagios 3522 May 26 03:28 Swap_Usage.xml.50439
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 22:13 Swap_Usage.xml.5044
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 22:13 Swap_Usage.xml.50443
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 12:35 Swap_Usage.xml.50455
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 11:40 Swap_Usage.xml.50461
-rw-rw-r-- 1 nagios nagios 3522 May 25 01:47 Swap_Usage.xml.50466
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 05:01 Swap_Usage.xml.50468
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 11:35 Swap_Usage.xml.50470
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 03:25 Swap_Usage.xml.50477
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 09:08 Swap_Usage.xml.50502
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 10:46 Swap_Usage.xml.50515
-rw-rw-r-- 1 nagios nagios 3522 May 28 18:50 Swap_Usage.xml.50523
-rw-rw-r-- 1 nagios nagios 3522 May 30 17:22 Swap_Usage.xml.50533
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 00:06 Swap_Usage.xml.5055
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 06:08 Swap_Usage.xml.50554
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 16:39 Swap_Usage.xml.50564
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 23:26 Swap_Usage.xml.50574
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 00:32 Swap_Usage.xml.50587
-rw-rw-r-- 1 nagios nagios 3522 May 26 13:24 Swap_Usage.xml.50590
-rw-rw-r-- 1 nagios nagios 3522 May 28 00:56 Swap_Usage.xml.50595
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 12:31 Swap_Usage.xml.50616
-rw-rw-r-- 1 nagios nagios 3522 May 26 01:28 Swap_Usage.xml.50631
-rw-rw-r-- 1 nagios nagios 3522 May 27 22:57 Swap_Usage.xml.50645
-rw-rw-r-- 1 nagios nagios 3522 Jun 16 01:31 Swap_Usage.xml.50647
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 14:39 Swap_Usage.xml.50663
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 15:43 Swap_Usage.xml.50696
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 11:05 Swap_Usage.xml.507
-rw-rw-r-- 1 nagios nagios 3522 May 28 02:56 Swap_Usage.xml.50701
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 12:18 Swap_Usage.xml.50704
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 04:30 Swap_Usage.xml.50711
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 19:56 Swap_Usage.xml.50722
-rw-rw-r-- 1 nagios nagios 3522 May 28 14:52 Swap_Usage.xml.50724
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 01:48 Swap_Usage.xml.50730
-rw-rw-r-- 1 nagios nagios 3522 May 30 23:20 Swap_Usage.xml.50734
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 00:58 Swap_Usage.xml.50737
-rw-rw-r-- 1 nagios nagios 3522 May 28 12:53 Swap_Usage.xml.50749
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 00:15 Swap_Usage.xml.50755
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 18:39 Swap_Usage.xml.50786
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 02:31 Swap_Usage.xml.50790
-rw-rw-r-- 1 nagios nagios 3522 May 28 08:54 Swap_Usage.xml.50792
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 14:02 Swap_Usage.xml.50798
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 22:52 Swap_Usage.xml.508
-rw-rw-r-- 1 nagios nagios 3522 May 27 01:09 Swap_Usage.xml.50820
-rw-rw-r-- 1 nagios nagios 3522 May 28 10:53 Swap_Usage.xml.50826
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 11:08 Swap_Usage.xml.50832
-rw-rw-r-- 1 nagios nagios 3522 May 28 16:51 Swap_Usage.xml.50850
-rw-rw-r-- 1 nagios nagios 3522 May 31 03:18 Swap_Usage.xml.50853
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 07:18 Swap_Usage.xml.50860
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 20:18 Swap_Usage.xml.50870
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 09:18 Swap_Usage.xml.50871
-rw-rw-r-- 1 nagios nagios 3522 May 27 07:07 Swap_Usage.xml.50874
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 05:28 Swap_Usage.xml.5088
-rw-rw-r-- 1 nagios nagios 3522 May 27 05:08 Swap_Usage.xml.50885
-rw-rw-r-- 1 nagios nagios 3522 May 31 07:17 Swap_Usage.xml.50895
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 12:23 Swap_Usage.xml.5091
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 16:25 Swap_Usage.xml.50910
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 20:22 Swap_Usage.xml.50920
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 16:28 Swap_Usage.xml.50930
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 06:15 Swap_Usage.xml.50941
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 17:29 Swap_Usage.xml.50947
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 06:30 Swap_Usage.xml.50961
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 16:57 Swap_Usage.xml.50978
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 06:49 Swap_Usage.xml.5099
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 03:16 Swap_Usage.xml.50994
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 09:09 Swap_Usage.xml.51015
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 11:49 Swap_Usage.xml.51033
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 13:07 Swap_Usage.xml.51036
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 22:56 Swap_Usage.xml.51047
-rw-rw-r-- 1 nagios nagios 3522 May 31 01:19 Swap_Usage.xml.51053
-rw-rw-r-- 1 nagios nagios 3522 May 25 09:44 Swap_Usage.xml.51059
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 02:44 Swap_Usage.xml.51061
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 02:53 Swap_Usage.xml.51065
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 10:23 Swap_Usage.xml.51097
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 10:45 Swap_Usage.xml.51103
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 21:04 Swap_Usage.xml.51127
-rw-rw-r-- 1 nagios nagios 3522 May 27 03:09 Swap_Usage.xml.51134
-rw-rw-r-- 1 nagios nagios 3522 May 28 20:50 Swap_Usage.xml.51169
-rw-rw-r-- 1 nagios nagios 3522 May 26 17:17 Swap_Usage.xml.51174
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 13:03 Swap_Usage.xml.51187
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 15:11 Swap_Usage.xml.51194
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 10:08 Swap_Usage.xml.51207
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 08:37 Swap_Usage.xml.51216
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 19:32 Swap_Usage.xml.51239
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 05:24 Swap_Usage.xml.51244
-rw-rw-r-- 1 nagios nagios 3522 May 25 15:37 Swap_Usage.xml.51263
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 00:55 Swap_Usage.xml.51284
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 04:53 Swap_Usage.xml.51291
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 15:06 Swap_Usage.xml.51326
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 15:11 Swap_Usage.xml.51331
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 03:02 Swap_Usage.xml.51345
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 20:05 Swap_Usage.xml.51358
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 02:57 Swap_Usage.xml.51369
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 21:55 Swap_Usage.xml.51373
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 01:25 Swap_Usage.xml.51388
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 12:45 Swap_Usage.xml.51399
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 03:48 Swap_Usage.xml.51423
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 20:38 Swap_Usage.xml.51430
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 02:54 Swap_Usage.xml.51442
-rw-rw-r-- 1 nagios nagios 3522 May 27 09:07 Swap_Usage.xml.51453
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 06:52 Swap_Usage.xml.51460
-rw-rw-r-- 1 nagios nagios 3522 May 24 14:20 Swap_Usage.xml.51484
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 22:59 Swap_Usage.xml.51497
-rw-rw-r-- 1 nagios nagios 3522 May 25 17:36 Swap_Usage.xml.51502
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 13:35 Swap_Usage.xml.51538
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 09:41 Swap_Usage.xml.51557
-rw-rw-r-- 1 nagios nagios 3522 May 27 11:06 Swap_Usage.xml.51558
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 18:33 Swap_Usage.xml.51562
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 17:32 Swap_Usage.xml.5157
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 21:36 Swap_Usage.xml.51575
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 09:17 Swap_Usage.xml.51591
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 05:47 Swap_Usage.xml.51594
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 18:56 Swap_Usage.xml.51601
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 19:05 Swap_Usage.xml.51626
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 23:22 Swap_Usage.xml.51658
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 02:20 Swap_Usage.xml.51662
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 22:50 Swap_Usage.xml.51674
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 18:04 Swap_Usage.xml.5168
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 05:47 Swap_Usage.xml.51682
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 13:39 Swap_Usage.xml.51690
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 00:12 Swap_Usage.xml.51692
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 21:04 Swap_Usage.xml.51697
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 02:14 Swap_Usage.xml.51698
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 10:02 Swap_Usage.xml.51699
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 04:06 Swap_Usage.xml.51742
-rw-rw-r-- 1 nagios nagios 3522 Jun 16 03:31 Swap_Usage.xml.51743
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 17:42 Swap_Usage.xml.51749
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 11:17 Swap_Usage.xml.51751
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 07:55 Swap_Usage.xml.51757
-rw-rw-r-- 1 nagios nagios 3522 May 31 21:17 Swap_Usage.xml.51765
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 05:15 Swap_Usage.xml.51769
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 03:24 Swap_Usage.xml.51831
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 13:04 Swap_Usage.xml.51838
-rw-rw-r-- 1 nagios nagios 3522 May 30 09:29 Swap_Usage.xml.51848
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 10:40 Swap_Usage.xml.51857
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 01:03 Swap_Usage.xml.51865
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 15:03 Swap_Usage.xml.51872
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 04:43 Swap_Usage.xml.51875
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 18:24 Swap_Usage.xml.51878
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 15:50 Swap_Usage.xml.51893
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 17:35 Swap_Usage.xml.519
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 00:01 Swap_Usage.xml.51900
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 14:30 Swap_Usage.xml.51908
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 22:27 Swap_Usage.xml.51923
-rw-rw-r-- 1 nagios nagios 3522 May 27 13:05 Swap_Usage.xml.51932
-rw-rw-r-- 1 nagios nagios 3522 May 28 22:49 Swap_Usage.xml.51934
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 04:52 Swap_Usage.xml.51963
-rw-rw-r-- 1 nagios nagios 3522 May 24 15:55 Swap_Usage.xml.51977
-rw-rw-r-- 1 nagios nagios 3522 May 25 11:43 Swap_Usage.xml.51991
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 08:08 Swap_Usage.xml.51995
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 03:19 Swap_Usage.xml.5200
-rw-rw-r-- 1 nagios nagios 3522 May 24 21:53 Swap_Usage.xml.52000
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 13:48 Swap_Usage.xml.52001
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 16:11 Swap_Usage.xml.52005
-rw-rw-r-- 1 nagios nagios 3522 May 30 05:31 Swap_Usage.xml.52010
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 19:43 Swap_Usage.xml.52012
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 19:05 Swap_Usage.xml.52033
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 17:10 Swap_Usage.xml.52041
-rw-rw-r-- 1 nagios nagios 3522 May 31 19:18 Swap_Usage.xml.52048
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 17:06 Swap_Usage.xml.52059
-rw-rw-r-- 1 nagios nagios 3522 May 26 17:52 Swap_Usage.xml.5206
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 19:28 Swap_Usage.xml.52072
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 22:05 Swap_Usage.xml.52080
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 20:07 Swap_Usage.xml.5210
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 12:44 Swap_Usage.xml.52103
-rw-rw-r-- 1 nagios nagios 3522 May 25 19:35 Swap_Usage.xml.52113
-rw-rw-r-- 1 nagios nagios 3522 May 30 07:30 Swap_Usage.xml.52126
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 22:21 Swap_Usage.xml.52141
-rw-rw-r-- 1 nagios nagios 3522 May 30 11:29 Swap_Usage.xml.52168
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 01:29 Swap_Usage.xml.5217
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 01:30 Swap_Usage.xml.52172
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 07:46 Swap_Usage.xml.52177
-rw-rw-r-- 1 nagios nagios 3522 May 31 17:19 Swap_Usage.xml.52191
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 04:22 Swap_Usage.xml.5220
-rw-rw-r-- 1 nagios nagios 3522 May 30 13:28 Swap_Usage.xml.52204
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 18:01 Swap_Usage.xml.52206
-rw-rw-r-- 1 nagios nagios 3522 May 31 15:19 Swap_Usage.xml.52221
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 21:32 Swap_Usage.xml.52223
-rw-rw-r-- 1 nagios nagios 3522 May 26 19:16 Swap_Usage.xml.52230
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 23:37 Swap_Usage.xml.52241
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 18:27 Swap_Usage.xml.52251
-rw-rw-r-- 1 nagios nagios 3522 May 24 17:54 Swap_Usage.xml.52257
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 04:57 Swap_Usage.xml.52268
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 14:34 Swap_Usage.xml.52288
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 20:53 Swap_Usage.xml.5230
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 23:04 Swap_Usage.xml.52308
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 03:28 Swap_Usage.xml.5231
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 22:37 Swap_Usage.xml.52318
-rw-rw-r-- 1 nagios nagios 3522 May 25 21:35 Swap_Usage.xml.52324
-rw-rw-r-- 1 nagios nagios 3522 May 31 13:20 Swap_Usage.xml.52392
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 12:08 Swap_Usage.xml.52401
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 10:36 Swap_Usage.xml.52403
-rw-rw-r-- 1 nagios nagios 3522 May 24 23:52 Swap_Usage.xml.52409
-rw-rw-r-- 1 nagios nagios 3522 May 25 10:19 Swap_Usage.xml.5241
-rw-rw-r-- 1 nagios nagios 3522 May 25 05:51 Swap_Usage.xml.52412
-rw-rw-r-- 1 nagios nagios 3522 May 30 03:32 Swap_Usage.xml.52419
-rw-rw-r-- 1 nagios nagios 3522 May 27 19:03 Swap_Usage.xml.52440
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 09:54 Swap_Usage.xml.52450
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 05:23 Swap_Usage.xml.52460
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 11:05 Swap_Usage.xml.52465
-rw-rw-r-- 1 nagios nagios 3522 May 24 19:54 Swap_Usage.xml.52472
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 00:59 Swap_Usage.xml.52489
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 17:02 Swap_Usage.xml.52493
-rw-rw-r-- 1 nagios nagios 3522 May 30 15:27 Swap_Usage.xml.52506
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 23:04 Swap_Usage.xml.52507
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 11:09 Swap_Usage.xml.52518
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 21:13 Swap_Usage.xml.5253
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 11:17 Swap_Usage.xml.52532
-rw-rw-r-- 1 nagios nagios 3522 May 26 05:32 Swap_Usage.xml.52534
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 08:51 Swap_Usage.xml.52536
-rw-rw-r-- 1 nagios nagios 3522 May 26 15:23 Swap_Usage.xml.52557
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 04:14 Swap_Usage.xml.52568
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 07:23 Swap_Usage.xml.52570
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 23:54 Swap_Usage.xml.52580
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 08:29 Swap_Usage.xml.52599
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 09:44 Swap_Usage.xml.5260
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 15:39 Swap_Usage.xml.52611
-rw-rw-r-- 1 nagios nagios 3522 May 30 01:32 Swap_Usage.xml.52613
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 14:45 Swap_Usage.xml.52615
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 15:03 Swap_Usage.xml.52617
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 17:03 Swap_Usage.xml.5262
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 08:46 Swap_Usage.xml.52622
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 05:14 Swap_Usage.xml.52623
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 06:42 Swap_Usage.xml.52632
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 14:17 Swap_Usage.xml.52633
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 09:05 Swap_Usage.xml.52656
-rw-rw-r-- 1 nagios nagios 3522 May 31 23:16 Swap_Usage.xml.52679
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 02:00 Swap_Usage.xml.5268
-rw-rw-r-- 1 nagios nagios 3522 May 26 21:16 Swap_Usage.xml.52686
-rw-rw-r-- 1 nagios nagios 3522 May 27 17:04 Swap_Usage.xml.52691
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 15:34 Swap_Usage.xml.52694
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 01:21 Swap_Usage.xml.52698
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 20:32 Swap_Usage.xml.52704
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 23:35 Swap_Usage.xml.52726
-rw-rw-r-- 1 nagios nagios 3522 May 26 07:31 Swap_Usage.xml.52732
-rw-rw-r-- 1 nagios nagios 3522 May 25 03:51 Swap_Usage.xml.52735
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 20:55 Swap_Usage.xml.52751
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 07:15 Swap_Usage.xml.52767
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 15:14 Swap_Usage.xml.5278
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 07:06 Swap_Usage.xml.52785
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 00:49 Swap_Usage.xml.52802
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 02:00 Swap_Usage.xml.52808
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 09:46 Swap_Usage.xml.52825
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 04:20 Swap_Usage.xml.52838
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 08:14 Swap_Usage.xml.52843
-rw-rw-r-- 1 nagios nagios 3522 May 27 15:05 Swap_Usage.xml.52845
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 19:41 Swap_Usage.xml.52851
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 16:38 Swap_Usage.xml.52854
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 20:40 Swap_Usage.xml.5286
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 21:05 Swap_Usage.xml.52884
-rw-rw-r-- 1 nagios nagios 3522 May 27 21:03 Swap_Usage.xml.52892
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 18:49 Swap_Usage.xml.529
-rw-rw-r-- 1 nagios nagios 3522 May 31 11:21 Swap_Usage.xml.52902
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 21:42 Swap_Usage.xml.52910
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 19:02 Swap_Usage.xml.52912
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 17:49 Swap_Usage.xml.52929
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 03:15 Swap_Usage.xml.52933
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 03:58 Swap_Usage.xml.52935
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 21:01 Swap_Usage.xml.52946
-rw-rw-r-- 1 nagios nagios 3522 May 26 11:29 Swap_Usage.xml.52960
-rw-rw-r-- 1 nagios nagios 3522 May 25 07:50 Swap_Usage.xml.52962
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 08:52 Swap_Usage.xml.52984
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 03:29 Swap_Usage.xml.52990
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 17:11 Swap_Usage.xml.52998
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 14:13 Swap_Usage.xml.530
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 13:55 Swap_Usage.xml.53001
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 02:12 Swap_Usage.xml.53004
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 07:47 Swap_Usage.xml.53014
-rw-rw-r-- 1 nagios nagios 3522 May 25 13:42 Swap_Usage.xml.53024
-rw-rw-r-- 1 nagios nagios 3522 May 26 09:30 Swap_Usage.xml.53025
-rw-rw-r-- 1 nagios nagios 3522 May 25 01:52 Swap_Usage.xml.53038
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 13:16 Swap_Usage.xml.53041
-rw-rw-r-- 1 nagios nagios 3522 May 30 21:25 Swap_Usage.xml.53062
-rw-rw-r-- 1 nagios nagios 3522 May 30 19:26 Swap_Usage.xml.53063
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 21:28 Swap_Usage.xml.53077
-rw-rw-r-- 1 nagios nagios 3522 May 28 05:00 Swap_Usage.xml.53083
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 13:17 Swap_Usage.xml.53084
-rw-rw-r-- 1 nagios nagios 3522 May 31 09:21 Swap_Usage.xml.53086
-rw-rw-r-- 1 nagios nagios 3522 May 25 23:34 Swap_Usage.xml.53100
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 06:56 Swap_Usage.xml.53107
-rw-rw-r-- 1 nagios nagios 3522 May 28 06:59 Swap_Usage.xml.53109
-rw-rw-r-- 1 nagios nagios 3522 May 26 13:29 Swap_Usage.xml.53110
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 00:26 Swap_Usage.xml.53129
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 03:29 Swap_Usage.xml.5313
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 12:01 Swap_Usage.xml.53145
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 01:16 Swap_Usage.xml.53161
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 17:38 Swap_Usage.xml.53162
-rw-rw-r-- 1 nagios nagios 3522 May 27 09:42 Swap_Usage.xml.5317
-rw-rw-r-- 1 nagios nagios 3522 May 26 03:33 Swap_Usage.xml.53172
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 19:10 Swap_Usage.xml.53193
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 06:01 Swap_Usage.xml.53199
-rw-rw-r-- 1 nagios nagios 3522 May 30 17:27 Swap_Usage.xml.53204
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 06:13 Swap_Usage.xml.53205
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 11:45 Swap_Usage.xml.53214
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 11:40 Swap_Usage.xml.53220
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 06:51 Swap_Usage.xml.53223
-rw-rw-r-- 1 nagios nagios 3522 May 26 01:33 Swap_Usage.xml.53233
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 14:43 Swap_Usage.xml.53235
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 22:18 Swap_Usage.xml.53241
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 10:51 Swap_Usage.xml.53245
-rw-rw-r-- 1 nagios nagios 3522 May 28 18:55 Swap_Usage.xml.53254
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 09:13 Swap_Usage.xml.53256
-rw-rw-r-- 1 nagios nagios 3522 May 28 21:25 Swap_Usage.xml.5327
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 23:31 Swap_Usage.xml.53289
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 16:44 Swap_Usage.xml.53312
-rw-rw-r-- 1 nagios nagios 3522 May 27 23:02 Swap_Usage.xml.53316
-rw-rw-r-- 1 nagios nagios 3522 May 28 01:02 Swap_Usage.xml.53350
-rw-rw-r-- 1 nagios nagios 3522 May 28 03:01 Swap_Usage.xml.53354
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 00:37 Swap_Usage.xml.53368
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 10:43 Swap_Usage.xml.5339
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 12:40 Swap_Usage.xml.53390
-rw-rw-r-- 1 nagios nagios 3522 May 30 23:25 Swap_Usage.xml.53395
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 21:56 Swap_Usage.xml.534
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 20:00 Swap_Usage.xml.53401
-rw-rw-r-- 1 nagios nagios 3522 May 28 08:59 Swap_Usage.xml.53403
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 12:36 Swap_Usage.xml.53413
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 06:34 Swap_Usage.xml.53451
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 04:35 Swap_Usage.xml.53457
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 01:53 Swap_Usage.xml.53467
-rw-rw-r-- 1 nagios nagios 3522 May 28 14:57 Swap_Usage.xml.53483
-rw-rw-r-- 1 nagios nagios 3522 May 25 16:12 Swap_Usage.xml.5349
-rw-rw-r-- 1 nagios nagios 3522 May 26 23:15 Swap_Usage.xml.53491
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 12:23 Swap_Usage.xml.53496
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 01:03 Swap_Usage.xml.53500
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 15:48 Swap_Usage.xml.53501
-rw-rw-r-- 1 nagios nagios 3522 Jun 16 01:36 Swap_Usage.xml.53502
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 02:36 Swap_Usage.xml.53507
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 00:20 Swap_Usage.xml.53515
-rw-rw-r-- 1 nagios nagios 3522 May 31 05:23 Swap_Usage.xml.53525
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 14:07 Swap_Usage.xml.53556
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 11:13 Swap_Usage.xml.53557
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 13:38 Swap_Usage.xml.5356
-rw-rw-r-- 1 nagios nagios 3522 May 27 01:14 Swap_Usage.xml.53563
-rw-rw-r-- 1 nagios nagios 3522 May 28 10:58 Swap_Usage.xml.53566
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 17:34 Swap_Usage.xml.53567
-rw-rw-r-- 1 nagios nagios 3522 May 28 16:56 Swap_Usage.xml.53586
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 07:23 Swap_Usage.xml.53596
-rw-rw-r-- 1 nagios nagios 3522 May 27 07:12 Swap_Usage.xml.53605
-rw-rw-r-- 1 nagios nagios 3522 May 25 18:11 Swap_Usage.xml.5361
-rw-rw-r-- 1 nagios nagios 3522 May 31 03:23 Swap_Usage.xml.53623
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 09:23 Swap_Usage.xml.53652
-rw-rw-r-- 1 nagios nagios 3522 May 27 05:13 Swap_Usage.xml.53656
-rw-rw-r-- 1 nagios nagios 3522 May 31 07:22 Swap_Usage.xml.53666
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 20:27 Swap_Usage.xml.53673
-rw-rw-r-- 1 nagios nagios 3522 May 31 01:24 Swap_Usage.xml.53676
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 03:21 Swap_Usage.xml.53680
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 16:30 Swap_Usage.xml.53710
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 16:33 Swap_Usage.xml.53726
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 17:02 Swap_Usage.xml.53771
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 13:12 Swap_Usage.xml.53773
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 02:58 Swap_Usage.xml.53774
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 02:49 Swap_Usage.xml.53813
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 11:54 Swap_Usage.xml.53819
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 09:14 Swap_Usage.xml.53831
-rw-rw-r-- 1 nagios nagios 3522 May 27 03:14 Swap_Usage.xml.53833
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 10:28 Swap_Usage.xml.53858
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 10:50 Swap_Usage.xml.53862
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 19:37 Swap_Usage.xml.53899
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 21:09 Swap_Usage.xml.53908
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 15:16 Swap_Usage.xml.53915
-rw-rw-r-- 1 nagios nagios 3522 May 26 17:22 Swap_Usage.xml.53940
-rw-rw-r-- 1 nagios nagios 3524 Jun 2 23:01 Swap_Usage.xml.53949
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 15:41 Swap_Usage.xml.5397
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 21:40 Swap_Usage.xml.5398
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 10:13 Swap_Usage.xml.53983
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 13:08 Swap_Usage.xml.53993
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 04:58 Swap_Usage.xml.54014
-rw-rw-r-- 1 nagios nagios 3522 May 25 15:42 Swap_Usage.xml.54016
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 15:11 Swap_Usage.xml.54023
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 08:42 Swap_Usage.xml.54035
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 01:00 Swap_Usage.xml.54041
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 20:10 Swap_Usage.xml.54057
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 03:07 Swap_Usage.xml.54068
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 05:29 Swap_Usage.xml.54069
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 15:16 Swap_Usage.xml.54097
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 22:00 Swap_Usage.xml.54120
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 20:43 Swap_Usage.xml.54131
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 01:30 Swap_Usage.xml.54140
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 03:53 Swap_Usage.xml.54156
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 21:39 Swap_Usage.xml.5417
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 03:03 Swap_Usage.xml.54174
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 09:12 Swap_Usage.xml.5419
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 12:50 Swap_Usage.xml.54205
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 12:53 Swap_Usage.xml.5424
-rw-rw-r-- 1 nagios nagios 3522 May 27 09:12 Swap_Usage.xml.54245
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 23:04 Swap_Usage.xml.54247
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 10:07 Swap_Usage.xml.54253
-rw-rw-r-- 1 nagios nagios 3522 May 24 14:25 Swap_Usage.xml.54261
-rw-rw-r-- 1 nagios nagios 3522 May 25 17:41 Swap_Usage.xml.54266
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 18:38 Swap_Usage.xml.54267
-rw-rw-r-- 1 nagios nagios 3522 May 27 11:11 Swap_Usage.xml.54268
-rw-rw-r-- 1 nagios nagios 3522 Jun 3 02:59 Swap_Usage.xml.54276
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 05:59 Swap_Usage.xml.5432
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 22:55 Swap_Usage.xml.54331
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 13:40 Swap_Usage.xml.54336
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 21:41 Swap_Usage.xml.54354
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 09:22 Swap_Usage.xml.54366
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 05:52 Swap_Usage.xml.54371
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 05:20 Swap_Usage.xml.54381
-rw-rw-r-- 1 nagios nagios 3522 May 24 18:19 Swap_Usage.xml.544
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 09:46 Swap_Usage.xml.54404
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 05:52 Swap_Usage.xml.54408
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 02:25 Swap_Usage.xml.54418
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 19:10 Swap_Usage.xml.54422
-rw-rw-r-- 1 nagios nagios 3522 Jun 10 19:01 Swap_Usage.xml.54426
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 21:09 Swap_Usage.xml.54427
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 15:46 Swap_Usage.xml.5443
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 22:31 Swap_Usage.xml.54430
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 04:11 Swap_Usage.xml.54452
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 02:20 Swap_Usage.xml.54463
-rw-rw-r-- 1 nagios nagios 3522 May 31 21:22 Swap_Usage.xml.54471
-rw-rw-r-- 1 nagios nagios 3522 Jun 8 16:07 Swap_Usage.xml.54473
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 13:44 Swap_Usage.xml.54480
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 08:00 Swap_Usage.xml.54496
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 00:17 Swap_Usage.xml.54503
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 17:47 Swap_Usage.xml.54516
-rw-rw-r-- 1 nagios nagios 3522 Jun 16 03:36 Swap_Usage.xml.54521
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 11:22 Swap_Usage.xml.54522
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 23:27 Swap_Usage.xml.54539
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 10:45 Swap_Usage.xml.54565
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 15:08 Swap_Usage.xml.54583
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 03:29 Swap_Usage.xml.54585
-rw-rw-r-- 1 nagios nagios 3522 May 30 09:34 Swap_Usage.xml.54587
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 01:08 Swap_Usage.xml.54602
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 18:29 Swap_Usage.xml.54655
-rw-rw-r-- 1 nagios nagios 3522 May 28 22:54 Swap_Usage.xml.54658
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 15:55 Swap_Usage.xml.54667
-rw-rw-r-- 1 nagios nagios 3522 May 27 13:11 Swap_Usage.xml.54669
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 03:32 Swap_Usage.xml.5468
-rw-rw-r-- 1 nagios nagios 3522 May 30 13:53 Swap_Usage.xml.547
-rw-rw-r-- 1 nagios nagios 3522 May 24 16:00 Swap_Usage.xml.54722
-rw-rw-r-- 1 nagios nagios 3522 Jun 11 14:35 Swap_Usage.xml.54729
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 04:57 Swap_Usage.xml.54736
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 21:36 Swap_Usage.xml.54737
-rw-rw-r-- 1 nagios nagios 3522 Jun 7 12:49 Swap_Usage.xml.54750
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 23:08 Swap_Usage.xml.54759
-rw-rw-r-- 1 nagios nagios 3522 Jun 12 13:53 Swap_Usage.xml.54767
-rw-rw-r-- 1 nagios nagios 3522 May 30 05:36 Swap_Usage.xml.54772
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 19:10 Swap_Usage.xml.54775
-rw-rw-r-- 1 nagios nagios 3522 Jun 6 17:15 Swap_Usage.xml.54784
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 16:17 Swap_Usage.xml.54786
-rw-rw-r-- 1 nagios nagios 3522 May 24 21:58 Swap_Usage.xml.54787
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 08:13 Swap_Usage.xml.54794
-rw-rw-r-- 1 nagios nagios 3522 May 31 19:23 Swap_Usage.xml.54796
-rw-rw-r-- 1 nagios nagios 3522 May 25 11:48 Swap_Usage.xml.54813
-rw-rw-r-- 1 nagios nagios 3522 Jun 13 01:35 Swap_Usage.xml.54814
-rw-rw-r-- 1 nagios nagios 3522 Jun 1 17:11 Swap_Usage.xml.54820
-rw-rw-r-- 1 nagios nagios 3522 Jun 4 22:09 Swap_Usage.xml.54826
-rw-rw-r-- 1 nagios nagios 3522 Jun 9 19:33 Swap_Usage.xml.54855
-rw-rw-r-- 1 nagios nagios 3522 Jun 5 00:05 Swap_Usage.xml.54857
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 18:32 Swap_Usage.xml.54863
-rw-rw-r-- 1 nagios nagios 3522 May 25 19:40 Swap_Usage.xml.54869
-rw-rw-r-- 1 nagios nagios 3522 Jun 15 19:48 Swap_Usage.xml.54876
-rw-rw-r-- 1 nagios nagios 3522 Jun 2 11:09 Swap_Usage.xml.54877
-rw-rw-r-- 1 nagios nagios 3522 Jun 14 22:26 Swap_Usage.xml.54884
-rw-rw-r-- 1 nagios nagios 3522 May 24 17:59 Swap_Usage.xml.54903
-rw-rw-r-- 1 nagios nagios 3522 May 30 07:35 Swap_Usage.xml.54905
-rw-rw-r-- 1 nagios nagios 384952 Jun 16 09:11 User_Count.rrd
-rw-rw-r-- 1 nagios nagios 2130 Jun 16 09:11 User_Count.xml
vtrac
Post
by vtrac » Wed Jun 16, 2021 10:46 am
How are you doing?
Great!! ... Based on your replied, I am assumed that the Apply Config works.
Looks like you are still having issue with "Swap_Usage.xml" file under "/usr/local/nagios/share/perfdata/jboss7/".
Do you have "root" or "sudo" privileges on your XI machine?
If so, let try to remove that file, since it might be corrupted or you might have a bad spot on that filesystem.
cd /usr/local/nagios/share/perfdata/jboss7/
sudo mv -f Swap_Usage.xml Swap_Usage.xml.bad
or
sudo rm -f Swap_Usage.xml
sudo touch Swap_Usage.xml
sudo chown nagios.nagios Swap_Usage.xml
sudo chmod 664 Swap_Usage.xml
Best Regards,
Vinh
theo481
Post
by theo481 » Tue Jul 13, 2021 10:12 am
This worked, thank you for the help
