While adding switch to NagiosXI Ports are missing for switch
nagioscynosure
Post by nagioscynosure »
When I am adding switch to Nagios XI through network Switch/ router wizard I am getting ports but some of ports are missing for that switch. As in Screenshot attached 46th port is not there.
So please can you suggest what can be the problem.
ssax
Dreams In Code
Re: While adding switch to NagiosXI Ports are missing for sw
Post by ssax »
Please attach your /etc/php.ini.
PM me this file for this system:
- Change X.X.X.X to the IP of the device
/usr/local/nagiosxi/tmp/mrtg-X.X.X.X
