Nagios XI - Can't Log Into The Web Interface on my Backup Se
fsodah
Post by fsodah »
I am not able to log in to my backup server via web interface even the username and password are correct, strange. I am sure username/password 100% since I use the auth on prod, the web interface is not showing an error message for login.
vtrac
Re: Nagios XI - Can't Log Into The Web Interface on my Backu
Post by vtrac »
How are you doing?
Here's the KB article I found which talked about not able to log into the web interface:
https://support.nagios.com/kb/article/n ... ce-25.html
My thought would be that your backup server not able to connect to the database.
Is your backup server has its own (local) database?
Best Regards,
Vinh
fsodah
Post by fsodah »
I’m great, thanks!
yes it has its own DB, it was working fine ... I will check with the article and get back to you.
vtrac
Post by vtrac »
Great!! ... :-)
fsodah
Post by fsodah »
Problem solved, many thanks .. please close the ticket.
vtrac
Post by vtrac »
Great!! ..... locking ticket .... :-)
