We need to monitor the in/out BW being consumed in our network devices, we are using this plugin check_rrdtraf in NagiosXI as this supports also the BW reporting but the result we currently have on both in/out is 0BW.
running this command LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
provides this output:
ERROR: Line 571 (Target[1.2.3.4_11111]: 11111:[email protected]:161::::2) in CFG file (/etc/mrtg/conf.d/1.2.3.4.cfg)
contains a duplicate definition for target[1.2.3.4_11111].
First definition is on line 4
I've deleted the RRDs of thosse that needs to be monitored but Im still getting the 0BW output when running the plugin
network bw monitoring 0 BW
Re: network bw monitoring 0 BW
Please check /etc/mrtg/conf.d for a config file for that specific device, it will be something like:
1.2.3.4.cfg
Look in there for duplicate targets.
There may also be duplication between /etc/mrtg/mrtg.cfg and /etc/mrtg/conf.d/1.2.3.4.cfg.
1.2.3.4.cfg
