hi i installed nagios 4 in centos7 and i monotored ssh mysql and os partitions and i need to monitor tomcat .for that i installed tomcat plugin.
but i am getting following error
(Return code of 127 is out of bounds. Check if plugin exists)
this error getting in nagios 4 ui
nagios 4 centos7 tomcat
benjaminsmith
Re: nagios 4 centos7 tomcat
Hi @manikanta,
Welcome to the Nagios Community Forum.
Let's see, are you using an agent? If you're using NRPE, take a look at our KB article for help troubleshooting.
https://support.nagios.com/kb/article/n ... g-613.html
Also, make sure you can run the plugin locally as the nagios user. It could be permissions on the plugin or the command is not defined in npre.cfg.
Let us know what you find out.
Benjamin
Benjamin
