Event Log not showing anything
acentek
Post by acentek »
Hi, I have two problems. I see nothing when I look at Monitoring Process > Event Log (on the Home page).
Also, the "oec.service" will not enable on the server. So when the server reboots the service doesn't start and that's bad.
ssax
Dreams In Code
Re: Event Log not showing anything
Post by ssax »
Please PM me a copy of your profile, you can download it from Admin > System Profile by clicking the Download Profile button.
You may have crashed DB tables, please send the output of these commands:
- NOTE: You may need to adjust the -h 127.0.0.1, the -uroot, and -pnagiosxi in the first command if your DB is offloaded to another server and/or you've changed the root mysql password
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
This next command may fail, that's okay, not all systems run postgresql, send the output anyways:
echo "SELECT relname as Table, pg_size_pretty(pg_total_relation_size(relid)) As Size, pg_size_pretty(pg_total_relation_size(relid) - pg_relation_size(relid)) as ExternalSize FROM pg_catalog.pg_statio_user_tables ORDER BY pg_total_relation_size(relid) DESC;" | psql nagiosxi nagiosxi
If the first command above shows NULL for any of the sizes (specifically for the event log it would be nagios_logentries), repair the databases:
https://assets.nagios.com/downloads/nag ... tabase.pdf
acentek
Post by acentek »
Thanks! PM sent with profile and the output from both commands you requested.
ssax
Dreams In Code
Post by ssax »
Tables look good.
I'm seeing a lot of these:
(70007)The timeout specified has expired: [client 192.168.18.109:52289] AH01075: Error dispatching request to : (polling)
Please run this command and send me the resulting /tmp/SUPPORTFILES.zip file:
zip -r /tmp/SUPPORTFILES.zip /etc/httpd/conf.d/php.conf /etc/php-fpm.d/www.conf /etc/php.ini /etc/my*
