How do I fix message Host Down CRITICAL rta nan, lost 100%?
I added a service from Configuration Wizards to monitor an ldap server, and this gives me a "Host Down: CRITICAL - serverX: rta nan, lost 100%" alert while the ldap service is working correctly. I think the problem is that I ping the server but this is not reachable by ping from my subnet, is it possible to fix this problem or at least hide the alert?
benjaminsmith
Re: How do I fix message Host Down CRITICAL rta nan, lost 10
Thank you for joining the Nagios Community forum!
Since the service is up, I suspect the server has pings disabled and I would check the settings on the server. Also, you can easily disable notifications for the host check-in the Core Configuration Manager to avoid any unwanted notifications.
Using The Core Config Manager For Host Management
https://assets.nagios.com/downloads/nag ... gement.pdf
Regards,
Benjamin
Regards,
Benjamin
