Change bandwidth decimal
ndc
Post by ndc »
Good afternoon.
I am running this command and it shows me in = .000048Mb / s
When it should show in = 48.00Mb / s
[root@nagios ~]# /usr/local/nagios/libexec/check_rrdtraf -f /var/lib/mrtg/sw.ndc.local_10101.rrd -w 150.00,150.00 -c 170,170.0 -l M
OK - Current BW in: 0Mbps Out: 0Mbps|in=.000048Mb/s;150.00;170 out=.000008Mb/s;150.00;170.0
Thank you.
ssax
Dreams In Code
Re: Change bandwidth decimal
Post by ssax »
Please note that the plugin is checking the average over the last 10 minutes.
What version of the plugin are you using?
/usr/local/nagios/libexec/check_rrdtraf  -V
Please attach this file:
Send the full output of this command:
/usr/local/nagios/libexec/check_rrdtraf -f /var/lib/mrtg/sw.ndc.local_10101.rrd -w 150.00,150.00 -c 170,170.0 -l M -vv
ssax
Dreams In Code
Post by ssax »
There is already a ticket open on this, please continue support through the ticket.
Locking the thread.
