NDRP - Send output from 1 nagios core to 2 nagiosXI servers
dberlenda
Post by dberlenda »
Hello ,
I success installalled NRDP and now I send the output of services monitored by my nagios core to nagiosXI with NRDP .
In my landscape I have 2 nagiosXI servers , one for dev and test system and another for production systems.
In some remote sites I have installed nagios core servees with svil , test and prod system monitored .
I tried without succcess to creare in the command.cfg 2 commands and add the follow line in the nagios.cfg file :
nagios.cfg :
# NRDP Send Data to NagiosXI
ochp_command=send_nrdp_host , send_nrdp_host_prod
ocsp_command=send_nrdp_service , send_nrdp_service_prod
command.cfg
command_name send_nrdp_host
command_line $USER1$/send_nrdp.php --url=http://xxx.xxx.xxx.xxx/nrdp/ --token=mytoken --host="$HOSTNAME$" --state=$HOSTSTATEID$ --output="$HOSTOUTPUT$"
command_name send_nrdp_service
command_line $USER1$/send_nrdp.php --url=http://xxx.xxx.xxx.xxx/nrdp/ --token=mytoken --host="$HOSTNAME$" --service="$SERVICEDESC$" --state=$SERVICESTATEID$ --output="$SERVICEOUTPUT$"
command_name send_nrdp_host_prod
command_name send_nrdp_service_prod
This is possible to send the output of services monitored by nagios core to 2 nagiosXI servers wth NRDP ?
Thanks in advance
Davide
gsmith
Re: NDRP - Send output from 1 nagios core to 2 nagiosXI serv
Post by gsmith »
Hi
Here's what I came up with. I create a command that calls a script that runs the send_nrdp command twice, once for each server.
So on the core machine I edited commands.cfg to add:
        command_name    nrdptwice
        command_line    $USER1$/nrdptwice $HOSTALIAS$ $HOSTSTATEID$ $HOSTOUTPUT$
I edited localhost.cfg and changed the host alias:
define host {
    use                     linux-server            ; Name of host template to use
                                                    ; This host definition will inherit all variables that are defined
                                                    ; in (or inherited by) the linux-server host template definition.
    host_name               localhost
    alias                   mycoreserver
    address                 127.0.0.1
and I defined a service:
    use                     local-service           ; Name of service template to use
    host_name               localhost
    service_description     nrdp2
    check_command           nrdptwice
in /usr/local/nagios/libexec I created a file called "nrdptwice":
#!/bin/sh
/usr/local/nrdp/clients/send_nrdp.php --url=http://192.168.23.81/nrdp/ --token=nrdptoken --host=$1  --state=$2 --output=$3
/usr/local/nrdp/clients/send_nrdp.php --url=http://192.168.23.82/nrdp/ --token=nrdptoken --host=$1  --state=$2 --output=$3
Give that a try.
