BPI groups
deek
BPI groups
Post by deek »
Hi ,
I have created 4 separate BPI groups . But Im not able to see all four of them under BPI section . So what could be the reason for that .
And if at all I want to edit the setting where can I do .
vtrac
Re: BPI groups
Post by vtrac »
Hope you are having a good day!! ... :-)
When creating a new BPI group, there are three "High", "Medium" and "Low" priorities options (please see picture below).
You might have select other "priority" for other two BPI groups.
Please click the "All Priorities" tab, you will see all your BPI groups.
To edit, please click the "Edit" icon on the far right of each group.
Best Regards,
Vinh
deek
Re: BPI groups
Post by deek »
Im not able to see all priorities option . Is it because of the Nagios version .
vtrac
Re: BPI groups
Post by vtrac »
Hi @deek,
Good morning!! ... :-)
Yes, looks like your Nagios XI is "5.5.10" and current released is "5.8.4" which explained why you do not see the "All Priorities" tab.
However, you should still be able to click on each (separate) tab like "High Priority", "Medium Priority" and "Low Priority" to be able to see your BPI groups you have defined.
Best Regards,
Vinh
