Hi Team,
Do we have any option to monitor file system names of the linux servers for the mount point.
we want to monitor the /dev/mapper/centos-root filesystem.
[toolsadmin@qy-nagios-a libexec]$ df -h
/dev/mapper/centos-root 150G 34G 117G 23% /
filesystem names monitoring
Re: filesystem names monitoring
Hello
Thanks for reaching out, and it appears that you would like to monitor a /dev/ mount point.
Have you taken a look at the 'check_disk' plugin? Here is an example that I plugged in:
Please let us know how that works for you,
Perry
./check_disk -w 10% -c 5% -p /dev/mapper/cl-root -C -w 100000 -c 50000 -p /
DISK OK - free space: / 7774 MiB (56.72% inode=98%);| /=5931MiB;12335;13020;0;13706
Perry
Hi!
Can you clarify? I'm not sure what you mean by "file system names".
Do you mean asking for file system status by passing the file system's LABEL? (ls -l /dev/disk/by-label)
