Hello Team,
for installation in prod server with the install script, Do we need to disable SElinux? please advice.
Nagios LS installation
Re: Nagios LS installation
Hi
You shouldn't. but tell me what OS you are running and I can test it.
You may have to deal with SElinux if it affects the rsyslog service.
Techmnagioslsuser
It is RHEL 8.9
Hi
During install you may get:
(Note: If semanage is not found then: yum install policycoreutils-python)
If port 5544 is not listed you need to add it:
Verify it was added:
Run the following:==============================! WARNING !====================================
SELinux is enforcing. This may prevent rsyslog from forwarding messages.
If log messages do not reach Log Server from this host, ensure SELInux is
configured to allow rsyslog forwarding.
semanage port -l | grep syslogCode: Select all
[root@localhost ~]# semanage port -l | grep syslog
syslog_tls_port_t tcp 6514, 10514
syslog_tls_port_t udp 6514, 10514
syslogd_port_t tcp 601, 20514
syslogd_port_t udp 514, 601, 20514Code: Select all
semanage port -a -t syslogd_port_t -p tcp 5544
semanage port -a -t syslogd_port_t -p udp 5544Code: Select all
syslogd_port_t tcp 5544, 601, 20514
syslogd_port_t udp 5544, 514, 601, 20514
Techmnagioslsuser
Sure , will update the same steps
