Wrong disk readings after resizing disk
alipoglavsek
Post by alipoglavsek »
Hi.
I have the following situation.
We have Nagios XI server installed on vmware (version 5.8.2).
NCPA agent (version 2.2.1) is installed on AIX server (7200-05-02-2114) and the readings for disk 'OraData' were correct for half a year now.
After extending disk from 15 TB to 16 TB (adding 1 TB), the readings are incorrect.
NCPA Output:
CRITICAL: Used disk space was -531.50 % (Used: -770.44 GiB, Free: 915.40 GiB, Total: 144.97 GiB)
Is there some limitation for disk or is this something else?
We did not change the command, it is still the same:
check_xi_ncpa!-t '$USER10$' -P 5693 -M 'disk/logical/|OraData' -w '98' -c '99'
Thanks in advance for any information.
Best regars, Aljaž
pbroste
Re: Wrong disk readings after resizing disk
Post by pbroste »
Hello Aljaž,
Thanks for reaching out about the disk size issue.
Sounds like the size of the disk partition was resized but the filesystem on the partition was not increased to match. Please check with the man pages on resize2fs on this. And here is an article that we also provide as well.
Perry
alipoglavsek
Hi, Perry.
It seems like we have misunderstood.
With Nagios XI we are monitoring AIX server (versin 7200-05-02-2114).
After extending filesystem on this AIX server from 15 TB to 16 TB we are getting wrong filesystem usage for /OraData.
For all other filesystems disk usage is showing correct values.
Here is the output on AIX server:
[email protected] /home/sa.vk# df -g
Filesystem GB blocks Free %Used Iused %Iused Mounted on
/dev/hd4 0,88 0,38 57% 18194 17% /
/dev/hd2 6,12 1,09 83% 77560 22% /usr
/dev/hd9var 2,50 0,91 64% 15507 7% /var
/dev/hd3 4,00 3,90 3% 2563 1% /tmp
/dev/hd1 2,12 1,20 44% 2024 1% /home
/proc - - - - - /proc
/dev/hd10opt 3,12 1,75 45% 24108 6% /opt
/dev/livedump 0,25 0,25 1% 4 1% /var/adm/ras/livedump
/dev/nmonlv 5,00 2,31 54% 800 1% /nmon
/dev/orahomelv 75,00 36,29 52% 286527 4% /OraBase1
/dev/oradatalv 16529,00 905,62 95% 654 1% /OraData
/dev/oraarchloglv 765,00 590,33 23% 731 1% /OraArchlog
/dev/oradiaglv 50,00 49,59 1% 3578 1% /OraDiag
/dev/oraflashlv 150,00 92,52 39% 322 1% /OraFlash
/dev/hd11admin 0,12 0,12 1% 11 1% /admin
/dev/RedoLog1lv 25,00 4,87 81% 14 1% /RedoLog1
/dev/RedoLog2lv 25,00 4,87 81% 14 1% /RedoLog2
jarovit:/home/razvoj01/prmzav/data 217,31 29,97 87% 271840 4% /home/razvoj01/prmzav/data
jarovit:/home/razvoj01/ppm0/data 217,31 29,97 87% 271840 4% /home/razvoj01/ppm0/data
jarovit:/home/razvoj01/sifranti/data 217,31 29,97 87% 271840 4% /home/razvoj01/sifranti/data
jarovit:/home/razvoj01/skode/data 217,31 29,97 87% 271840 4% /home/razvoj01/skode/data
jarovit:/home/razvoj01/docarch/data 217,31 29,97 87% 271840 4% /home/razvoj01/docarch/data
Best regards, Aljaž
pbroste
Post by pbroste »
Hello Aljaž,
Thanks for following up with the details. We see that your '/dev/oradatalv 16529,00 905,62 95% 654 1% /OraData' results in correct total size.
We want to get some further data points from this mount point to determine what is going on.
Please run the following and provide the results:
du -h -d 0 /OraData -c | grep -Ei 'total'
Verbose output on the ncpa command:
/usr/local/nagios/libexec/check_ncpa.py -H [yourhostip_or_name] -t '[your_ncpa_token]' -P 5693 -M 'disk/logical/|OraData' -w '98' -c '99' -v
Perry
ssax
Dreams In Code
Post by ssax »
What type of filesystem is it? (JFS/JFS2/ext4/etc)
Did you restart the ncpa_listener service after and see if that resolves it?
NCPA uses the psutil python library to get the information, I was seeing some PPC 16TB limits for memory/JFS/JFS2 while researching this but I'm not sure how that translates into what psutil is reading from the backend or if it's related at all.
alipoglavsek
Perry, hi.
Sorry for late reply, but I have been absent.
Here are the outputs you asked for:
dev-srv-devana@root /# /opt/freeware/bin/du -h -d 0 /OraData -c | grep -Ei 'total'
16T total
And the second one for this command:
File returned contained:
"returncode": 2,
"stdout": "CRITICAL: Used disk space was -448.30 % (Used: -649.84 GiB, Free: 794.80 GiB, Total: 144.97 GiB) | 'used'=-649.84GiB;142;144; 'free'=794.80GiB;142;144; 'total'=144.97GiB;142;144;"
BTW: filesystem is JFS2
Best regards, Aljaž
ssax
Dreams In Code
Post by ssax »
Please create a bug report for this here with your AIX system info/oslevel/etc so that the developers can investigate the issue:
https://github.com/NagiosEnterprises/ncpa/issues
You may need to use a plugin with NPCA as a workaround until they release a fix, it has to be related to psutils because that's where the data is taken from.
See here:
https://exchange.nagios.org/directory/P ... ms/details
And here:
https://support.nagios.com/kb/article/n ... a-722.html
alipoglavsek
Bug issue created, thank you.
BR, Aljaž
ssax
Dreams In Code
Post by ssax »
Thank you, the developers will see it, they may ask for additional information but that looks good.
alipoglavsek
Hi, do I have to do anything on github (add some developer or something), because there is still no answer?
Thanks, Aljaž
