Services with delayed Apply config
dslaughter
Post by dslaughter »
I was adding new services and didn't finish and left the services config screen up and didn't apply changes. When I returned to finish the service work several of the hosts I was adding services to removed all their services. I saw a message about unused services were being removed. When I applied the changes the services came back but metric data is missing for the time period I didn't apply changes.
Is this the expected behavior if I don't apply changes quickly?
gsmith
Re: Services with delayed Apply config
Post by gsmith »
Hi
I am try to replicate this now. Were you using the Core Config Manager to add services?
Also please create a system profile for me.
To send us your system profile.
1. Login to the Nagios XI GUI using a web browser.
2. Click the "Admin" > "System Profile" Menu
3. Click the "Download Profile" button
4. Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
gsmith
Post by gsmith »
I have not been able to reproduce the error.
That being said, the use case of leaving a configuration in 'edit mode' for eight hours
is not something that has been designed for or tested, so it is considered to be an
unsupported condition.
dslaughter
ok, Close this thread. I'll make sure to apply changes if I do have to walk away for a while.
