I recently deleted a user from my Nagios instance and there was no confirmation prompt after clicking on the red X to delete the user. When you delete a contact for example, there is a popup confirmation, but no such confirmation happened for the user deletion.
Do other folks experience the same? If so, should this be filed as a bug?
Deleting a user does not prompt for confirmation?
PeaceCorpsLinuxTeam
Re: Deleting a user does not prompt for confirmation?
You are correct, there is no pop-up confirmation when you delete a user.
It does make sense to have a confirmation. I’ve submitted a feature request
to add this ability to the product on your behalf.
Please keep in mind that the decision to implement an enhancement is at
the discretion of our development team.
