Change Notification Type From "PROBLEM"
vornado
Post by vornado »
Good morning, all.
Linux 3.10.0-1160.31.1.el7.x86_64
Nagios XI 5.8.4
Host with NCPA plugin: Windows 10 Enterprise 20H2
I have a monitor that notifies me when files have been uploaded to a directory. In the notification email, the "Notification Type" is "PROBLEM". Since this is not really a problem, I would like to change it -- for this particular monitor only -- to something like "NOTIFICATION". Is this possible?
Thanks.
Steve
vtrac
Re: Change Notification Type From "PROBLEM"
Post by vtrac »
Hi Steve,
How are you doing?
The only way I know how to change from "PROBLEM" to "NOTIFICATION" is:
Click on your username at the upper right corner of Nagios XI page > Notification Messages > "Email" tab
Change "%TYPE%" to NOTIFICATION .... please NOTE, this will change ALL your future notifications to says "NOTIFICATION".
Here's the "%TYPE% definition:
I'm very sorry, but I could not find a better way where you can custom the notification for just this ONE particular service check.
Best Regards,
Vinh
vornado
Post by vornado »
Thanks for your reply, Vinh. I already know I could change it for all emails. :) I was hoping I could customize it for one service check. I guess the value of the variable %TYPE% cannot be changed programmatically in my plugin.
vtrac
Post by vtrac »
I'm very sorry, but there is not a way to customize the notification for just this ONE particular service check.
May I close this thread?
Best Regards,
Vinh
vornado
Post by vornado »
Yes, you may close the thread -- thanks for your help. If you could possibly pass it on as a feature request, that would be great. :D
vtrac
Post by vtrac »
I have just opened a new feature request "15593" as requested.
Locking thread!! .... :-)
Best Regards,
Vinh
