Down Option for Flapping and Stalking Options Not Saving?
jaimie.livingston
Post by jaimie.livingston »
Is anyone else having issues saving Flapping or Stalking options for Down events using CCM?
I'm doing pre-testing of v5.8.4 and I've noticed that I cannot save Flapping or Stalking options for Down events.
The CCM GUI shows the button for the Down option, and on first glance it looks like the setting is being saved, but when the object or template is reopened, the Down option is unselected, and the Down option flag is not listed in the config file.
~Jaimie
ssax
Dreams In Code
Re: Down Option for Flapping and Stalking Options Not Saving
Post by ssax »
Please PM me a copy of your profile, you can download it from Admin > System Profile by clicking the Download Profile button.
PM me the host/service name that you are seeing this on.
Are you saying the flapping/stalking options in the CCM for hosts/services aren't saving? (there isn't a down option for either of those so I'm just clarifying to make sure I'm understanding your issue properly. I labbed it up in XI 5.8.4 and it's saving properly.
jaimie.livingston
The 5.8.5 update appears to have fixed the issue.
If the issue returns, I'll address it in a new post.
Jaimie
vtrac
Post by vtrac »
Great!! .... locking thread ... :-)
