From few days ago I receive Service Check Timed Out message for Networking & VM Status. I tried to increase the value of service_check_timeout but no results.
I assume that this error appeared after I configurated AD integration for that VM.
Is someone who has encountered this problem ?
CPU Usage for VMHost Ok 22h 56m 0s 1/5 2012-06-27 10:24:03 ESX3 OK - cpu usage=2777.29 MHz (9.65%)
Datastore usage for VMHost Ok 22h 54m 15s 1/5 2012-06-27 10:22:32 ESX3 OK - storages : Datastore1=1511744.00 MB (66.19%)
Input / Output for VMHost Ok 18h 49m 37s 1/5 2012-06-27 10:20:25 ESX3 OK - io commands aborted=0, io bus resets=0, io read latency=0 ms, write latency=0 ms, kernel latency=0 ms, device latency=0 ms, queue latency=0 ms
Memory for VMHost Ok 18h 53m 0s 1/5 2012-06-27 10:22:10 ESX3 OK - mem usage=11825.61 MB (48.13%), overhead=536.35 MB, swapped=0.00 MB
Networking for VMHost Critical 23h 12m 51s 5/5 2012-06-27 10:22:02 (Service Check Timed Out)
Services for VMHost Ok 22h 53m 42s 1/5 2012-06-27 10:20:58 ESX3 OK - services : DCUI (up), TSM (down), TSM-SSH (down), lbtd (up), lsassd (up), lwiod (up), netlogond (up), ntpd (up), vmware-vpxa (down)
VM Status for VMHost Critical 23h 12m 18s 5/5 2012-06-27 10:21:31 (Service Check Timed Out)
