Just found this page:
https://support.nagios.com/kb/article/n ... es-14.html
Am I correct in understanding that it is not recommended to install NAgios client into an already existing environment? That seems a difficult challenge and something that should be made more clear.
What is the preferred/recommended approach to monitoring a pre-existing system?
Many thanks!!
Installing a new client
Re: Installing a new client
Sorry for the confusion. That article is referring to the installation of Nagios XI server.
The idea being that Nagios XI is running on a dedicated server.
As you surmised, adding a Nagios client to an existing environment is definitely supported.
