Nagios Not logging on
optionstechnology
Post by optionstechnology »
I can no longer log into my nagios box - I can get to the login screen, but as soon as I enter the user/pass it just refreshes back to the login screen again
I know its the right username/pass because if I purposely put the wrong details in it tells me the user/pass is incorrect... so its definitely consulting the user database, just its not getting past the login screen
running 5.8.3 CentOS Linux release 7.9.2009
gsmith
Re: Nagios Not logging on
Post by gsmith »
Ok lets look at the logs. Please capture a system profile. You can PM it to
me for security reasons. Please reply to this topic once you have sent it.
You'll have to use the command line to generate it:
rm -rf /usr/local/nagiosxi/var/components/profile*
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORT
Then send me the resulting /usr/local/nagiosxi/var/components/profile.zip​ file.
optionstechnology
sent
gsmith
Post by gsmith »
Hi
The profile is incomplete, which leads me to believe you are out of diskspace.
Could you please try freeing some up? Once you have done that see if you can log in,
if you can't please try capturing another System Profile for us.
optionstechnology
oh yikes your absolutely right - rookie mistake!
Thats it fixed now, cheers
this can be closed
