Have a situation where we cannot apply changes through the Gui. Can make and save them, but not apply them.
The status indicators for:
Monitoring Engine
Performance Grapher
Database Backend
Are all red.
We're running 5.6.5, an install from source. on Redhat 7.9. Php 5.4.16
From an alerting and visual standpoiny, everything else seems to be working. Alerts are going out, the status page is up to date, and usage graphs are as well.
Tried to do a profile build
but got:
profile build failed
Array
Code:1
I can "view" the system profile from System Config-System profile. But if I attempt to download it. I get the error.
NagiosXi status in red - but still working - mostly
sherlocknag
Re: NagiosXi status in red - but still working - mostly
How are you doing?
You might have a crash in your database.
Please run the below commands
Now, please open the Nagios XI GUI > Configure > Core Config Manager > Config File Management
Please click "Delete Files", do ot worry ... we will re-write them
Please click "Write Configs"
Please click "Verify Files"
Now, please click "Apply Configuration" on upper left panel > "Apply Configuration"
If you are still experience issue with "Apply Configuration", please post the "profile.zip".
If you're unable to generate the the profile through the web interface,
please try generating it from the command line by running these commands as root:
rm -rf /usr/local/nagiosxi/var/components/profile*
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORT
or older system:
/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh SUPPORT
Best Regards,
Vinh
How are you doing?
/usr/local/nagiosxi/scripts/repair_databases.sh
rm -f /usr/local/nagios/etc/import/*
or older system:
Best Regards,
Vinh
