Hey guys,
Thanks to some of you I finally managed to have the check_autoit script installed and running properly.
Now what I'd like to do next is generate a report from the results and email it every 3 hours. Also if it's possible I'd like to add some graphs to the email as well.
Can this be done?
Thanks!
Graphs and Reports
Re: Graphs and Reports
I sent you a PM regarding this. Glad that you got the scripts working!
I'm not sure if my message got back to you,slansing wrote:I sent you a PM regarding this. Glad that you got the scripts working!
but I found this plugin:
http://exchange.nagios.org/directory/Ad ... er/details
ever gave it a go?
Why don't you give that plugin a try, if you have any issues with it post back here!
