Hello everyone,
I apologize, I did not know which argument to write, I hope it's the appropriate section.
where I work now I need to control all different PC-based Windows (XP, VISTA, 7).
about twenty computers.
I would maybe use a simple program installed on a central machine as server and its client to install the agent software, which allows me to have a vision of how we use the same, banda how much I care, a percentage that software is using more of such sites surf ...
I have heard much good of your software but I do not know where to start, help? a guide? Support in Italian?
and can do all this with your software?
Thanks to all in advance
where to start?
Re: where to start?
What exactly are you looking to monitor on the machines? If you could give us some examples we could see if Nagios has the solution for you.
Re: where to start?
I would like to monitor what programs they use, how much network bandwidth are working on, sail on such sites, if there is the possibility to be created is a network map ...
Re: where to start?
You can start by reviewing our Administrator's guide here:
http://assets.nagios.com/downloads/nagi ... nistrator/
There you can find information on how to monitor Windows machines, Websites, etc. The Network Status Map is included in Nagios XI by default.
Unfortunately, we don't provide support in Italian. I am sorry for the inconvenience.
Please, let us know if you have any specific questions or difficulties with using Nagios XI.
