I'm using NCPA to monitor a Windows machine with NRDP (passive check) and quite sure there's no port blocking issue as Windows firewall is now off.
The strange thing is "Memory Usage" can be monitored successfully, but all the others namely "CPU Load" and "Uptime" always show "connect to address x.x.x.x and port 12489: Connection refused".
All service configurations are identical except "check command" of course. I wonder if port 12489 really can't be reached then why "Memory Usage" is not affected?
port 12489 Connection refused issue
Re: port 12489 Connection refused issue
Are you sure you're using the right plugin to communicate with the right agent? 12489 is typically the NSClient++ default port. NCPA listens on 5693 by default.
Hello mcapra,
May be I'm confused of the method of collect passive data.
I've associated the default command
and thought that it can use for passive check. Its seems that this is not the correct command for this case.
I've read the guide about Nagios + NRDP + NCPA. But there's only commands for active check.
Do you know where I can find those commands for passive check?
check_nt -H $HOSTADDRESS$ -p 12489 -v $ARG1$ $ARG2$I've read the guide about Nagios + NRDP + NCPA. But there's only commands for active check.
I've finally found a useful guide "Using-NCPA-For-Passive-Checks.pdf" on the web. This document has given me a great help and my problem is now solved.
