I am using check_nrpe to run a script/batch file to return a registry value.
The values that is possible to be returned can be 4 different values
Values:
0x0
0x1
0x2
0x3
My goal is when the values 0x0,0x2, and 0x3 is present it should be at critical state, 0x1 should be ok state. i also want to add a message to the critical alert for example 0x0 = critical state the message i want to add is "host is in disabled mode" or is it easier to add this to my returned value?
here is my current script.
@echo off
for /F "tokens=3" %%A in ('reg query "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\swin\Parameters" /v "RTEMode"') DO (ECHO %%A)
exit 0
any help is appreciated.
script help needed
Re: script help needed
Hi
Could you please verify the registry path:
I am not seeing it.
I am not seeing it.
gsmith wrote:Hi
I am not seeing it.
gsmith this is a mcafee application we run(you prob dont run this application), I am able to get the value into nagios, but i want the additional parameters added like the criticle alert and the message/text describing the value.
Hi
Here's some psuedocode:
The return codes Nagios recognizes are:
0 for OK
1 for Warning
2 for Critical
3 for Unknown
You can "echo" anything you want.
Does this help?
@echo off
if "0x1" == "0x1" echo "OK"
EXIT /B 0
if (warning condition) echo "WARNING"
EXIT /B 1
if (value is one of: 0x0,0x2,0x3) echo "CRITICAL"
EXIT /B 2
if (unknown condition) echo "UNKNOWN"
EXIT /B 30 for OK
1 for Warning
2 for Critical
3 for Unknown
Does this help?
