Every hour Nagios has a high load
riahc3
Post by riahc3 »
Hello
When making new hosts, I usually just copy the config file over and done. Never has been a issue.
I did this again but now Nagios, every hour, has a unusual high load every hour. From what I can observe from top, it seems to be a issue with httpd.
Ive restarted it and all over Nagios related services but nothing.
There are no crontabs that I can see.
Any ideas?
Thank you
Re: Every hour Nagios has a high load
Post by mcapra »
In Nagios Core, there's a pretty finite number of things that would spike httpd specifically, and it's usually the CGIs or pnp4nagios. Are you running any sort of reporting behind-the-scenes?
In Nagios XI, there's several things that could spike httpd specifically.
