Pages in GUI Failing to Load
wneville
Post by wneville »
This morning when I navigated to the SNMP Trap Interface, it repeatedly failed to load. What I saw is attached as "trap interface fail.png" I am having the same issue on the Unconfigured Objects page but nowhere else on the site. Do you know what may be causing this issue? I looked in a number of logs and didn't see anything that seemed relevant. Any additional ideas on how to troubleshoot this? I may also need to clear the unconfigured objects/received traps as that has not been done in a few days. Can I access that from the CLI?
wneville
Re: Pages in GUI Failing to Load
Post by wneville »
Looks like I removed what I thought was an unused version of jquery - issue resolved
pbroste
Post by pbroste »
Hello @wneville,
Thanks for reaching out and then following up to let us know that the issue is resolved.
We will go ahead and lock it.
Perry
