I know the bulk modification>remove contact>select contact>find relationship ....process
On the user dashboard it is showing 300+ hosts and 4000+ services.
But, When I go through find relationships option it is reflecting 94 hosts and related services.
I even checked from the server by using grep command. The contact is in 94 config files only.
Why is it showing like this?.
I want the to delete the contact from multiple hosts and services. Is there any alternative option left?
Any help would be appreciated
Deleting a contact from multiple hosts & services
wipro-nagios-service
benjaminsmith
Re: Deleting a contact from multiple hosts & services
If that's not the issue, please send over the system profile and I can double-check the configs. Thanks, Benjamin
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Is that everything in the configs? Check the user security settings to make sure "can see all host and services" is not enabled. Go to Admin > Manage Users > .. and then click on the user link.On the user dashboard it is showing 300+ hosts and 4000+ services.
Hi Benjamin,
I missed out the point that the user might be in contact group and that is what happened. I have removed the contact from the group.
Sorry for that
Sorry for that
benjaminsmith
Hi @wipro-nagios-service,
Not a problem. Good to hear you got it sorted out.
We'll go ahead and close this one out.
--Benjamin
--Benjamin
