Fresh offline install of 5.8.5.1 on RHEL8.
Root's mail has logrotate failures:
/etc/cron.daily/logrotate: error: error setting owner of /usr/local/nagiosxi/var/cleaner.log-20210816 to uid 5557 and gid 100: Operation not permitted error: error setting owner of /usr/local/nagiosxi/var/dbmaint.log-20210816 to uid 5557 and gid 100: Operation not permitted error: error setting owner of /usr/local/nagiosxi/var/sysstat.log-20210816 to uid 5557 and gid 100: Operation not permitted
nagios is
uid=5557(nagios) gid=100(users) groups=100(users),5559(nagcmd),5560(nagios)
looks like rotating is failing anyway:
[root@mondevappla001 logrotate.d]# ls -l /usr/local/nagiosxi/var/clean*
-rw-r--r-- 1 nagios users 6995086 Aug 16 16:14 /usr/local/nagiosxi/var/cleaner.log
-rw------- 1 nagios nagios 0 Aug 14 03:12 /usr/local/nagiosxi/var/cleaner.log-20210814
-rw------- 1 nagios nagios 0 Aug 15 03:25 /usr/local/nagiosxi/var/cleaner.log-20210815
-rw------- 1 nagios nagios 0 Aug 16 03:27 /usr/local/nagiosxi/var/cleaner.log-20210816
Not sure why it is using gid 100 the logrotate stanza says
/usr/local/nagiosxi/var/*log {
missingok
notifempty
size 5M
copytruncate
su nagios nagios
rotate 1
compress
Zebee
logrotate errors - setting user/group
Re: logrotate errors - setting user/group
Hello @zebee
Thanks for reaching out on the logrotate issue. Looking over the details we are not sure why it is running the logrotate as 'user' and want to start by digging in a bit.
We would expect to see the following permissions:
so it looks like this:
Now that we verified let's run the logrotation manually from command with logging and debug:
Please review and send the /tmp/logrotate_results.txt to me via Private Message along with the System Profile so we can see what is going on.
To send us your system profile.
Perry
Andls -lahrt /etc/logrotate.d/nagiosxi
-rw-r--r-- 1 root root /etc/logrotate.d/nagiosxi
Option to add create 0664 nagios nagios to your /etc/logrotate.d/nagiosxils -ldhrt /usr/local/nagiosxi/var
drwxrwxr-x 7 nagios nagios 4.0K Aug 16 12:56 /usr/local/nagiosxi/var
missingok
notifempty
size 5M
copytruncate
su nagios nagios
rotate 1
compress
logrotate -f -v -d --log /tmp/logrotate_results.txt /etc/logrotate.d/nagiosxiTo send us your system profile.
- Login to the Nagios XI GUI using a web browser.
- Click the "Admin" > "System Profile" Menu
- Click the "Download Profile" button
- Save the profile.zip file and share
Perry
