it is not possible to delete services
supportcl
Post by supportcl »
I have 2 hosts with some services that I need to delete, but when I try to do it, it tells me the following
"Could not find a unique id for this service
Service cannot be deleted using this method "
But when I go to the "core config manager" and look for the services, they do not appear.
gsmith
Re: it is not possible to delete services
Post by gsmith »
Hi
Please send me a System Profile so I can troubleshoot:
To send us your system profile.
1. Login to the Nagios XI GUI using a web browser.
2. Click the "Admin" > "System Profile" Menu
3. Click the "Download Profile" button
4. Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
supportcl
Post by supportcl »
hello, I have sent you the requested file
Thank you
gsmith
Post by gsmith »
Got it - looking at it now.
Thx
gsmith
Post by gsmith »
Hi
Which hosts need services deleted? And what services are failing to be deleted?
supportcl
Post by supportcl »
Server: EACVMPFSW1
Service: Serv. pronostico de cada region y ciudad - Nodo1
Servidor: EACVMPFSW2
Service: Serv. pronostico de cada region y ciudad - Nodo2
those are the services that cannot be removed and do not appear in the list
gsmith
Post by gsmith »
Hi
I do not see those services associated with those hosts.
Can you you go to "Host status", search for each host, go to the Services tab and take a screenshot for me?
supportcl
Post by supportcl »
There goes an image, the other host is the same
gsmith
Post by gsmith »
Interesting... I don't see it on my system.
Please do the following:
  • Choose Configure, Core Config Manager
    Under Tools in the left-hand menu select Config File Management
    Hit the "Delete Files" (red) button - it's OK to do this
    Hit the "Write Configs" (blue) button
    Optional but informative - hit the "Verify Files" (white button)
    In the left-hand menu under Quick Tools select Apply Configuration
    Click the "Apply Configuration" (blue) button
If that doesn't solve the issue please follow this document and do a database repair;
https://assets.nagios.com/downloads/nag ... tabase.pdf
Let me know how things go please.
supportcl
Post by supportcl »
It is fixed, it was not necessary to read the PDF, with the previous instructions it was solved.
Thanks!
