Dark mode - text on upgrade bar is barely readable
jasoncrev
Post by jasoncrev »
Might have gotten missed when configuring dark mode. I assume the text color should be something other than white.
dchurch
Re: Dark mode - text on upgrade bar is barely readable
Post by dchurch »
Yes, unfortunately there are still some styling issues floating around when operating in Dark Mode.
Part of the move to Nagios XI 6 is revamping the styling and replacing most of the stylesheets with ones that work better with dark mode. It's in the works, but it's not ready yet.
Is this styling error preventing the update from completing?
jasoncrev
Post by jasoncrev »
No, it's not preventing the upgrade from completing; because it's just a style on the page. The style itself has nothing to do with what's going on with the upgrade.
dchurch
Post by dchurch »
I've reported this to the dev team, and they tell me it'll be fixed in release 5.8.6.
