REHL install and required packages
jbennett
Post by jbennett »
Is there a list of required packages anywhere?
I have done a quick search, and the only thing I find is for SLES10 from 2009: http://community.nagios.org/2009/08/12/ ... tallation/
Would it be possible to get a complete list of required packages for a clean install on a RHEL VM?
Re: REHL install and required packages
It is very important to start with a minimal install of RHEL and let Naigos XI do the install of the packages as some will depend on what version and architecture you are running.
The only ones I can think of off the top of my head before the install starts is wget and curl
The article you reference isn't for XI
