HTTP Content - String containing quotation marks
danallery
Post by danallery »
Hi there,
I am trying to use check_xi_service_http to search for:
"sealed":false
However the " marks are removed during the parse time. How do I force these to be searched for by the command?
pbroste
Re: HTTP Content - String containing quotation marks
Post by pbroste »
Hello @danallery
Thanks for reaching out; understand that you want to check for "text".
./check_http -H www.yourwebsite.com -s ""sealed":false"
I am thinking that we may require the quotes around the complete search, even though it is searching for "sealed":false (will need to test).
Perry
danallery
Post by danallery »
Thanks for the reply, Perry. I did initially try that method, however it would seem that any " quotation marks are ignored that sit within the first and last quotation mark.
I have read this...
and found this:
Note that certain special characters need to be escaped. For instance, the < should be replaced with \x3C so
as not to interfere with the XML. Within POST data URL escapes are used, so for instance @ becomes %40.
The problem is I do not know how to format the string, utilizing the scape characters... or what the escape character for " is!
danallery
Post by danallery »
I resolved this by using the check_Json function in the end. The page I was monitoring was JSON attribute output, so worked fine.
pbroste
Post by pbroste »
Hello @danallery
Thanks for following up and providing the plugin that worked for your use case, this will help others as well. I will go ahead and lock this.
