Hello all,
Is there a listing / domain tree of all the IP/CIDR of Nagios network that we would need for operations ( installing, XI operations, updates, etc).
Our security team recently instituted ASN blocking and seems to have caught most Nagios ops. We tried to whitelist with FQDN/domains but it seems like only IPs/CIDRs work.
Would it be possible for someone to provide the aforementioned?
Best,
Dusan
Need Nagios IP/CIDR list for ASN blocking
Dusan.Mandic
Re: Need Nagios IP/CIDR list for ASN blocking
Hi Dusan,
I don't think we have a list handy, but here are what I know:
nagios.com 45.33.1.79
nagios.org 45.33.126.74
support.nagios.com 66.228.48.232
api.nagios.com 50.116.21.73
exchange.nagios.org 66.228.58.94
repo.nagios.com / assets.nagios.com 45.79.49.120
Regards,
Vinh
Regards,
Vinh
Dusan.Mandic
Thanks Vinh,
Our NagiosXI server also gets an error stating it was unable to check for updates. Is this a seperate URL than what is listed above?
The check for update used the below URL:
https://www.nagios.com/checkforupdates/ ... i&version=.......
So "www.nagios.com" is used and already included in the list proviced.
Vinh
Vinh
Dusan.Mandic
We already have Nagios IP above whitelisted, I think its using a mirror, errors out when trying to receive update status.
host 50.116.21.73
73.21.116.50.in-addr.arpa domain name pointer newvs1.nagios.com
host 50.116.21.73
You might be right!!
I'm sorry but I don't have any info on "45.33.120.111" ...
Vinh
Vinh
Dusan.Mandic
host 50.116.21.73
posted wrong IP sorry
Yup, that could be the one doing the "auto_update_check".
Vinh
Vinh
Dusan.Mandic
OK. Are there any more like this you can think we would run into? Have to do it by IP/CIDR, so we cant really cast a wide net
There is not really an official list for this, so those are all that I can think of ...
Vinh
Vinh
