Hi Team,
We have enabled monitoring on windows servers using snmp window wizard. We are getting error for physical memory utilization.
we are using below command.
/usr/local/nagios/libexec/check_snmp_storage.pl -H <IP Address> -C <Community string> --v2c -m 'Physical Memory' -w 80 -c 90 -f
o/p : Unknown storage : Physical Memory : ERROR
Please help, Thanks in advance
SNMP Physical memory utilization service error
Thanks & Regards,
I2MP Team.
I2MP Team.
Re: SNMP Physical memory utilization service error
SO when you use the Windows SNMP wizard there are a few items checked by default for monitoring.
Mine looks like: Is "Physical memory usage" the only one giving you trouble?
Is it the only one you have configured?
Hi Team,
As below we are using all default ticked services but in c drive and physical memory only we are gettion error.
Please let me know if any addition data is required. Kindly check screenshot.
Thanks in advance.
Thanks in advance.
Thanks & Regards,
I2MP Team.
I2MP Team.
Please check the command for "Drive C: Disk Usage" If there is a "^" character before the "C:"
characters in the command please remove it and force a check on that service.
From a CLI on the Nagios server please run:
Here are my results for comparison.
[root@localhost tmp]# snmpwalk -v2c -c public 192.168.23.96 | grep StorageDesc
HOST-RESOURCES-MIB::hrStorageDescr.1 = STRING: C:\\ Label: Serial Number 4e07b61a
HOST-RESOURCES-MIB::hrStorageDescr.2 = STRING: D:\\ Label:CENA_X64FREE_EN-US_DV5 Serial Number d388b443
HOST-RESOURCES-MIB::hrStorageDescr.3 = STRING: E:\\ Label:New Volume Serial Number 2c37ce97
HOST-RESOURCES-MIB::hrStorageDescr.4 = STRING: Virtual Memory
HOST-RESOURCES-MIB::hrStorageDescr.5 = STRING: Physical Memory
Let me know what you find out please.
snmpwalk -v2c -c public 192.168.23.96 | grep StorageDesc[root@localhost tmp]# snmpwalk -v2c -c public 192.168.23.96 | grep StorageDesc
C drive issue resolved.
below is the result for command.
[nagios@eu2napu002 ~]$ snmpwalk -v2c -c Public IP | grep StorageDesc
HOST-RESOURCES-MIB::hrStorageDescr.1 = STRING: Physical RAM
HOST-RESOURCES-MIB::hrStorageDescr.2 = STRING: Virtual Memory
HOST-RESOURCES-MIB::hrStorageDescr.3 = STRING: (C:) System
HOST-RESOURCES-MIB::hrStorageDescr.4 = STRING: (D:) Data
HOST-RESOURCES-MIB::hrStorageDescr.5 = STRING: (Z:) *Empty unit*
Thanks & Regards,
I2MP Team.
I2MP Team.
Go to Configure, CCM, Services
Find the service for the Physical Memory that isn't working.
Edit that service - in the $ARGS1$ field change
-m "Physical Memory"
to:
-m "Physical RAM" Remember to Save your changes and to Apply Configuration
Please let me know it turns out.
to:
Thanks issue is resolved
Thanks & Regards,
I2MP Team.
I2MP Team.
