Migrating from Nagios Core to Nagios XI
fsbeaunix
Post by fsbeaunix »
I am migrating from Nagios Core to Nagios XI. I have a check in nagios core that is called check_web_ping_wrapper under the services config. Under the command expansion i have the commands and it looks like it points to an .sh (see screen shot also).
Nagios core:
Command Name Command Line
To expand: check_web_ping_wrapper
check_web_ping_wrapper $USER1$/check_http_wrapper.sh $HOSTNAME$
-> $USER1$/check_http_wrapper.sh $HOSTNAME$
How do I go about setting this up in Nagios XI? I am not too familar with nagios core as i didn't set it up, but have tried to migrate all of our notifications over. This one looks to have a script it uses.
vtrac
Re: Migrating from Nagios Core to Nagios XI
Post by vtrac »
Please following the below KB article on how to add new plugin into Nagios XI.
Let for example, once you have create the new plugin, you can then add a command name called "check_web_ping_wrapper".
This then has a command line of "$USER1$/check_http_wrapper.sh $HOSTNAME$"
You can manually run the command by open a command prompt on your Nagios XI and run:
/usr/local/nagios/libexec/check_http_wrapper.sh x.x.x.x
Regards,
Vinh
