Hello
I'm using Nagios core 4.4.6 on OpenSUSE 15.3. I was wandering if someone here can help with some settings. I am trying to push Nagios notification on a Discord webhook. So far I have try this method:
https://github.com/ReenigneCloud/nagios ... ifications - it didn't work for me.
Also, I have try this tutorial also, with apprise, but that *.yml file doesn't work for me
https://nuxref.com/tag/discord/
Any ideas?
Thank you!
Nagios Discord notification
benjaminsmith
Re: Nagios Discord notification
I would recommend opening an issue on the GithHub for that script. Normally you would pass the macros used in the notification as arguments in the notify-host-by-discord command setup. I don't see that part (take a look at the default notification commands).
Let us know if you get it working.
Benjamin
Did you get any error message (check the nagios.log)?https://github.com/ReenigneCloud/nagios ... ifications - it didn't work for me.
Benjamin
Thank you for your reply!
I was getting this errors with that script:
./send-discord-host.sh: line 28: + : syntax error: operand expected (error token is "+ ")
./send-discord-host.sh: line 29: + : syntax error: operand expected (error token is "+ ")
I did open an issue on Github. Also, I wasn't sure what to edit that script at - Nagios domain, used for generating our URLs
nagios_domain="" - script link: https://github.com/ReenigneCloud/nagios ... rd-host.sh
Any other suggestion?
I found a lot of stuff for Slack, but nothing for Discord.
Cheers!
Cheers!
