Hi All,
I have a problem that I was wondering if someone could help with.
I have been adding a few Servers to the monitoring software as normal today without a problem. I then went back in to change an group memeber of a contact group, run the verification (as normal) which came back as OK. I then went to restart the services to put the changes into effect, and I got the following error:
Nagios Core 3.2.3
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 10-03-2010
License: GPL
Error: Cannot open main configuration file '/etc/nagios/objects/service' for reading!
Warning: Cannot open log file '/var/nagios/nagios.log' for writing
Nagios 3.2.3 starting... (PID=4559)
Local time is Fri Jun 29 11:13:26 BST 2012
Bailing out due to one or more errors encountered in the configuration files. Run Nagios from the command line with the -v option to verify your config before restarting. (PID=4559)
If I run the verfiy option again, it still comes back with no issues detected:
Reading configuration data...
Read main config file okay...
Processing object config file '/etc/nagios/objects/commands.cfg'...
Processing object config file '/etc/nagios/objects/contacts.cfg'...
Processing object config file '/etc/nagios/objects/timeperiods.cfg'...
Processing object config file '/etc/nagios/objects/templates.cfg'...
Processing object config file '/etc/nagios/objects/localhost.cfg'...
Processing object config file '/etc/nagios/objects/xxxx.cfg'...
Processing object config file '/etc/nagios/objects/xxxxx.cfg'...
Processing object config file '/etc/nagios/objects/xxxxxx.cfg'...
Checking services...
Checked 140 services.
Checking hosts...
Checked 101 hosts.
Checking host groups...
Checked 9 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 12 contacts.
Checking contact groups...
Checked 9 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 24 commands.
Checking time periods...
Checked 5 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Any Ideas, as I have never seen this issue before!!
Many Thanks!
Error restarting Nagios Service
Re: Error restarting Nagios Service
What output do you get when you run the following command?
Also, it would probably help if you posted your nagios.cfg.
ls -l /etc/nagios/objects/service /var/nagios/nagios.log-
adityavatsa
Hello All,
I also faced similar problem. I removed few devices which were no longer supposed to be monitored by Nagios. While compiling I got following error:
Error: Cannot open main configuration file '/etc/nagios/objects/sites/-v' for reading!
Please suggest a solution for this and let me know if you need some more inputs.
Thanks!
Thanks!
You got this error while compiling? Were you trying to upgrade and you saw this error? Please post the exact commands you ran and their error output.adityavatsa wrote:I also faced similar problem. I removed few devices which were no longer supposed to be monitored by Nagios. While compiling I got following error:
adityavatsa
I used following command to compile :
nagios –v /etc/nagios/nagios.cfg
And I got the following error message:
Error: Cannot open main configuration file '/root/–v' for reading!
Nagios 3.2.3 starting... (PID=21254)
Local time is Tue Aug 05 08:36:09 CEST 2014
Bailing out due to one or more errors encountered in the configuration files. Run Nagios from the command line with the -v option to verify your config before restarting. (PID=21254)
Thanks!
Thanks!
That's not the command to compile nagios; that is the command to verify your configuration is correct. Try running the command again but instead of just "nagios" give it the full path to the nagios program.
