Monitoring Way Too Many Services
omarrrthepirate
Post by omarrrthepirate »
Hello folks. When I bulk added all my Cisco switches and routers, I did not mean to monitor all their ports, which each count as a service. So now we have around 300 hosts and over 14,000 services. My boss only wanted me to monitor all the ports on a few key switches and routers; not all of them. Is there a bulk way to remove ports from the switches you select? Or do I need to delete all these devices and re-import them without monitoring all their ports? Thank you kindly.
Omarrr The Pirate!
Arrrrr
vtrac
Re: Monitoring Way Too Many Services
Post by vtrac »
Did you use "hostgroup" or "servicegroup" for this?
If not, you will have to either manually delete each service .... or delete them all and re-do it using a hostgroup or servicegroup Inheritance.
https://support.nagios.com/kb/article/n ... e-691.html
https://assets.nagios.com/downloads/nag ... tance.html
Regards,
Vinh
