Passive Monitoring
Musthaq Hassan
Passive Monitoring
Post by Musthaq Hassan »
Hi Team,
We are planning to use NRDP client for Passive Monitoring. We are looking for details on list of supported operating system with its minimum & maximum release version on Windows and Linux.
We have RHEL version starting with 6.x
Windows we have 2012
Could you please help with details?
Thank you,
pbroste
Re: Passive Monitoring
Post by pbroste »
Hello @Musthaq
Thanks for reaching out, NRDP is being phased out and is replaced with NCPA.
Please check out the following:
Please let us know if you have further questions.
Perry
Musthaq Hassan
Thanks for your reply, I can see supported OS version for NCPA 2.3.1 as below,
Windows Server 2008+
RHEL 7.x & 8.x
AIX 7.x supported with NCPA Version 2.2.1
If customer wants to go with nrdp for passive monitoring, whether it will support RHEL 6.x, 7.x & Wndows Server 2012?
pbroste
Post by pbroste »
Hello @Musthaq
First, off correction, I should have stated that NRPE is on the way out *(or getting phasing out). NRPD is not getting phased out to correct my previous post.
You are correct that it will support RHEL 6.x, 7.x & Wndows Server 2012 utilizing NCPA to run passive check.
Perry
