Migration advice from CentOS 7 NXI 5.7 to RHEL 8 NXI 5.8
GhostRider2110
Post by GhostRider2110 »
I have been searching but really can't seem to get the search down to what I am looking for here.
Current system
CentOS 6.10 (started with Nagios VMware image)
Nagios XI 5.7.5
New system
RHEL 8
Upgrade Nagios XI to latest
What I want is advice to this migration. My plan
Deploy new RHEL 8 system
Install latest version of Nagios XI
Run restore from backup old system
Test
Clone to new system which will over the IP address off the original Nagios XI system.
Where is the flaw in my plan?
Mitch
pbroste
Re: Migration advice from CentOS 7 NXI 5.7 to RHEL 8 NXI 5.8
Post by pbroste »
Hello @GhostRider2110
Thanks for reaching out and sending along your plan. You will also want to make sure that you use the same hostname and IP address on the new. You will also want to make sure that both servers are running on the same Nagios XI/Core versions. The option to run the upgrade once you have completed the migration too.
Here is a support article that provides the layout as well:
https://support.nagios.com/kb/article/migrating-nagios-xi-to-a-different-server-892.html
Perry
GhostRider2110
Thanks, I'll let you know how it goes...
pbroste
Post by pbroste »
Excellent, please let us know if you need anything further on the server migration,
Perry
