How to change the default parameters of a plugin?
supportcl
Post by supportcl »
I am using the wizard that nagios XI brings to configure linux and windows systems (using NCPA) all fine, but I would like to be able to leave certain parameters "by default", such as:
check_xi_ncpa! -t 'password' -P 5693 -M memory / swap -u 'Gi' -w '5' -c '10' !!!!!!!
check_xi_ncpa! -t 'password' -P 5693 -M memory / swap -u 'Gi' -w '60' -c '80' !!!!!!!
I want the numbers to change from 5 to 60 and from 10 to 80 when configuring new servers. How can I edit that?
ssax
Dreams In Code
Re: How to change the default parameters of a plugin?
Post by ssax »
Currently you would need to change them in the wizard in order for them to be like that.
The only way to do it currently would be to change the default values in the wizard source-code but those changes will be reverted on an upgrade.
