UBUNTU - What user does nagios core execute as
jmd8045
Post by jmd8045 »
I am getting problems when nagios executes a remote check command
stuff like [Remote command execution failed: Host key verification failed. ] I have ssh keys set up between hosts
for root, but I am guesing there is something else going on. A typical command that failes is:
/usr/lib/nagios/plugins/check_by_ssh -4 -t30 -p1201 -H $HOSTADDRESS$ "/usr/lib/nagios/plugins/check_disk -w 10% -c 5% -p /tmp -p /var -C -w 100000 -c 50000 -p /"
Any help appreciated!
Jim
agriffin
Re: UBUNTU - What user does nagios core execute as
Post by agriffin »
It executes as the 'nagios' user. Try setting up your ssh between the nagios users on each of your systems and see if that helps.
