Install of Nagioslogserver 2.1.9 fails
HIINNS
Post by HIINNS »
All,
I have tried installing Nagioslogserver ver 2.1.9 and it fails because the elasticsearch service doesn't come up. Below is the error message derived from sudo systemctl status elasticsearch.service.
Last login: Tue Sep 7 07:15:01 EDT 2021 on cron
● elasticsearch.service - Elasticsearch
Loaded: loaded (/usr/lib/systemd/system/elasticsearch.service; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2021-09-07 06:41:13 EDT; 36min ago
Docs: https://www.elastic.co
Process: 7490 ExecStart=/usr/share/elasticsearch/bin/systemd-entrypoint -p ${PID_DIR}/elasticsearch.pid --quiet (code=exited, status=1/FAILURE)
Main PID: 7490 (code=exited, status=1/FAILURE)
Sep 07 06:41:13 myserver systemd-entrypoint[7490]: Error: A fatal exception has occurred. Program will exit.
Sep 07 06:41:13 myserver systemd-entrypoint[7490]: at org.elasticsearch.tools.launchers.JvmOption.flagsFinal(JvmOption.java:119)
Sep 07 06:41:13 myserver systemd-entrypoint[7490]: at org.elasticsearch.tools.launchers.JvmOption.findFinalOptions(JvmOption.java:81)
Sep 07 06:41:13 myserver systemd-entrypoint[7490]: at org.elasticsearch.tools.launchers.JvmErgonomics.choose(JvmErgonomics.java:38)
Sep 07 06:41:13 myserver systemd-entrypoint[7490]: at org.elasticsearch.tools.launchers.JvmOptionsParser.jvmOptions(JvmOptionsParser.java:135)
Sep 07 06:41:13 myserver systemd-entrypoint[7490]: at org.elasticsearch.tools.launchers.JvmOptionsParser.main(JvmOptionsParser.java:86)
Sep 07 06:41:13 myserver systemd[1]: elasticsearch.service: main process exited, code=exited, status=1/FAILURE
Sep 07 06:41:13 myserver systemd[1]: Failed to start Elasticsearch.
Sep 07 06:41:13 myserver systemd[1]: Unit elasticsearch.service entered failed state.
Sep 07 06:41:13 myserver systemd[1]: elasticsearch.service failed.
benjaminsmith
Re: Install of Nagioslogserver 2.1.9 fails
Post by benjaminsmith »
HI,
We are going to close this post as it's a duplicate.
Ben
