Somehow some of my hosts have a notification interval of 60 seconds still and we do not want more than one notification when a device goes down. But my hosts are al over the place. I bulk imported them all and at that point i believe I set the notification interval to 0 and it's also set to zero on most of my templates. But is there a global way to tell all hosts to set their notification interval to 0?
Looking for a Global Action for Notification Interval
omarrrthepirate
Omarrr The Pirate!
Arrrrr
Arrrrr
Re: Looking for a Global Action for Notification Interval
Hi
Yes, there sure is.
Go to Configure, Core Config Manager. In the left-hand menu pane under Tools
you'll want to select Bulk Modification Tool.
Here is a video I made showing the "picks and clicks". You'll have to rename it from .txt to .mp4 Here's a short instructional video about the tool: https://youtu.be/JkQij9smGfw
Yes, there sure is.
omarrrthepirate
You're awesome! Thank you for showing me that. Super useful!!!
Omarrr The Pirate!
Arrrrr
Arrrrr
I'm glad to help you out.
